Hard Starting...ARG!! - Defender Source
Old September 23rd, 2006, 05:23 PM
arbik
Arbi Karapetian
1995 D-90 SW #163/500
Hi All,
so I resolved the no-start problem. My fuel pump was bad, so I replaced it with a new fuel pump, and a new fuel filter, and the truck starts now. It runs fine, idles fine, and has power.
However, It needs to crank quite a few times for it to start.
I looked for fuel leaks, but htere are none.
what can this be?
by the way, prior to the fuel pump going bad, the truck used to start with half a crank.
-arbi
Old September 23rd, 2006, 06:55 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Could be the ignition switch at the beginning stages of going out. It stops triggering the coil, so everything is "sounding" right except for not starting. If it gets worse, this could be it. It can be intermittant, too. I think it is due to arcing until it just won't arc anymore...
Old September 24th, 2006, 09:19 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
check your coil to distributor wire.. My ends are getting a bit too corroded and it takes a fe more cranks to start because of it. (this is todays project)
good luck
-steve
Old September 24th, 2006, 09:35 AM
btate
Bryan Tate
d90
What about plugs, maybe fouled from a series of "no-starts"??
Simple to check......just a thought to check the basics
Old September 25th, 2006, 12:22 PM
arbik
Arbi Karapetian
Thanks for the replies guys. here is what I know:
-Plugs were bone dry, because my "no starts" were due to fuel pump failiure. I checked, and they're in good condition, and dry.
-Plug wires are about a year old, and they're in good condition. I made sure they're all plugged in correctly.
-The truck, started on the first half crank, before the fuel pump went out, so I'm not sure how it broke down during the 1.5 weeks it took me to replace the fuel pump.
-I checked for leaks from the fuel line, to see if it was loosing pressure, but there are no visible leaks.
-i double checked all the hose clamps on the intake side, and jiggled all the air flow meter connectors, and coil connectors.
So, now what?
-arbi
Old September 25th, 2006, 02:56 PM
jimngo's Avatar
jimngo
Jim Ngo
1994 D90 #80
Maybe a stupid question, but is the fuel filter installed in the right direction? You should also check the fuel pressure. I think it's supposed to be around 40 PSI.
Old November 2nd, 2006, 05:32 PM
arbik
Arbi Karapetian
What is a good way to check the fuel pressure? Where do you tap to check it?
THis hard starting problem is lingering..and on some days..It feels like its not going to start at all..
then it'll catch...stumble a little bit..then it runs fine.
Checked the fuel filter, its put on in the right direction. Not quite sure what else to check....
-arbi
Old November 2nd, 2006, 06:11 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
I once saw a no-start problem that was caused by an ignition connector under the dash. The guy checked fuel pressure, changed coil, dist and rotor and still no start. Finally, he jiggled the key while starting and it fired right up. He had to replace the connector from under the dash coming from the key. Just a thought. Give it a jiggle and see if it fires up...the key that is.
Old November 2nd, 2006, 08:32 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
I would suspect electrical, ignition or fuel based issue as the truck ends up starting (i.e. not air). [Yes, I know.... This is not helping much]
Did you leave to truck outside/in the rain/humidity in the last 2 weeks (compared to before where maybe it was sleeping in your garage)? I guess I am trying to understand if there is anything in the last two weeks that was different than before.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old November 6th, 2006, 09:24 AM
arbik
Arbi Karapetian
New Findings...
Ok.
So I got another piece to the puzzle.
The car is hard starting, but pushing the gas pedal all the way down helps start it.
I'm thinking, maybe the problem is the throtle position motor.
I checked the wires to it and it seems like its on there pretty good.
I hought if this unit was maulfunctioning, that the engine would throw codes. The check engine light is not on.
Any ideas?
-arbi
Old November 7th, 2006, 01:08 PM
MonLand
Loic Fabro
Just an FYI: I just replaced my stepper motor that was bad and not throwing any code. In my case, it was stuck open. Can you check if it is stuck half-way closed?
MonLand
1995 D90 NAS
1996 Discovery NAS
start, starting
Hard Starting 94 D90 Raleigh D90 Defender Technical Discussions 1 April 6th, 2009 11:21 AM
Hard starting while cold. Hans Defender Technical Discussions 0 December 5th, 2008 03:51 PM
Hard Top for sale Mark Cama For Sale - Parts 0 August 31st, 2005 09:19 AM
Hard Top and Stuff ron For Sale - Parts 22 November 14th, 2004 06:35 PM
Hard starting, everything else fine? Doug Defender Technical Discussions 16 July 11th, 2004 01:25 PM
