hard start / rough idle after, mostly during wet condition - Defender Source
Old August 20th, 2012, 10:58 AM
corrumpu
chris b
1995/RRC SWB
So i have a 3.9L (it's technically in a RRC SWB 95, but being it's the same as the defender engine.. figured you guys could shed some light)
It's a hard start occasionally. Usually after it sits a few days (like at the airport). It's my daily driver and has been great but recently it's becoming more cantankerous.
It starts hard after sitting or during wet weather. After it does start it's a rough idle which need a steady foot but it gets over this after 20+ seconds of idle and then it seems to get over it. Runs great the rest of the time. Couple this issue with a drain somewere on my battery and my daily driver is getting harder and harder to keep using daily!
Any thoughts or directions? I am not a mechanic, but usually do my own work after much googling, forum searching and RAVE. This issue seems to require more debugging than my internet searches bring up. Any help is appreciated.
--chris
Old August 20th, 2012, 11:06 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Sounds like a wet dizzy. A quick test is to take the distributor cap off, spray with CRC 5-56 (or similar), and see if that solves your issue. If so, purchase a new distributer rotor and cap.
Old August 20th, 2012, 11:21 AM
Check the vacuum hoses around the intake manifold. Your symptoms are classic vacuum leak. The hoses may look good but have a crack underneath or in an area that's hard to see. The major one that fails is the one for the cruise control vacuum system. If your cruise control isn't working that's usually why and it will give the engine fits.
idle, start
Starting / Rough Idle Problems 1985 V8 MeanGreen Defender Technical Discussions 16 October 25th, 2011 05:33 PM
Occasional Hard To Start and Now The Engine Spontaneously Dies artpeck Defender Technical Discussions 3 June 23rd, 2009 09:49 PM
Rough idle, stumbling, dying.... revtor Defender Technical Discussions 9 January 10th, 2008 04:28 PM
Hard Top for sale Mark Cama For Sale - Parts 0 August 31st, 2005 09:19 AM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
» Defender Registry
Yamelo
Pumkin
natas
Add your Defender
