Hard Brake Popping - Defender Source
Old December 21st, 2006, 08:32 AM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Hard Brake Popping
Any ideas of what would cause a popping sound when I brake hard? My D110 makes a loud pop sound when I brake hard. There is another pop sound that will follow a hard brake once I start to accelerate fast. The sound is comming from the front under the driver's side.
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old December 21st, 2006, 09:40 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
14 year old radius arm bushings?
Old December 21st, 2006, 11:36 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Bingo!
Email:
Old December 21st, 2006, 12:45 PM
Jon_Winningham
Sterling M Archer
Thanks guys!!!!!!!!!!!!!!
I just ordered new ones!!!!!!!!!!!!!!!!!!!
Old December 21st, 2006, 01:38 PM
Cirbo's Avatar
Cirbo
Jim C.
If you replace both ends of the radius arms, both ends of the trailing links, and both ends of the pan-hard rod, you will think you're driving a Ferrari.
J(Ferrari driver)C
Old December 21st, 2006, 01:54 PM
Please check your caliper bolts too - you will get a noise on braking if they start to loosen - and you'll get a very exciting experience if one of them backs out completely...
Old December 21st, 2006, 07:11 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
Not to bring the energy down but I had a 110 that made one pop on harsh decel to a stop and then one pop again after starting to move. It could be repeated easily. This was a result of the output shaft on the manual trans splines wearing. The noise was the main shaft of the trans slapping against the input of the t-case. This is probably not what you are experiencing but after checking and replacing a lot of bushings and u-joints I found this to be my problem. There was an updated input shaft for the t-cases that helped it to be lubricated introduced this area in the late 90s but by the time I found this out I needed to replace the main shaft of the tranny.
Old December 22nd, 2006, 08:45 AM
ECR's Avatar
ECR
Thats usually more of a "clack" than a "pop/ping" and it usually is associated with getting on and off the gas. He said this noise is a "pop" and coming from the front wheel area and is associated with braking. It is impossible to internet diagnose anything, but from his description, loose or bad radius arm bushings would be the first place to look.
Email:
Old December 22nd, 2006, 12:15 PM
Jon_Winningham
Sterling M Archer
I tightened the radius arms and the Pop seems to have stopped. I have a skid plate that covers the whole front axel that mounts to the bolts on the radius arms. There is barely enough threads left on the bolt to clear the nut. I got a full turn on each bolt!
Thanks again everyone for the great advise.
brake
Parking brake problem, handle popping back UP. Hans Defender Technical Discussions 14 January 19th, 2010 02:34 PM
Hard brake lines! TwisteD90 Defender Technical Discussions 10 October 10th, 2005 12:12 PM
Hard Top for sale Mark Cama For Sale - Parts 0 August 31st, 2005 09:19 AM
Brake pedal is hard!!?? Vadim Defender Technical Discussions 9 January 25th, 2005 01:09 PM
