Hard Brake Line to Caliper - Defender Source
Old July 2nd, 2010, 07:50 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
It was inevitable, I snapped one of the front hard brake lines that connect from the flexible line (and bracket at the top of the hub/caliper/axle) and screw into the caliper. Rovers North wants $70+ each for these lines - too much money. Are there any other off the shelf options?
I thought the brakes would be done this weekend....
Jerod
Old July 2nd, 2010, 07:57 PM
Order a whole set of stainless from classic tube -- or, I believe they will sell you just the little ones if you ask nicely.
http://www.eastcoastrover.com/DefenderSSpipes.html
http://www.classictube.com/
Ron
Old July 2nd, 2010, 08:42 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Is that the "Ron Good" solution? Looks like $600 for a whole set.
Is it hard to replace all the lines?
Old July 2nd, 2010, 10:27 PM
1994-1997 NAS Defender 90 complete brake pipe set
$333. for the complete set, plus installation
"Ron good" would be to wander into my basement and pluck one off a spare axle or figure out how long it is and order a short piece of metric line and bend it myself.
All the lines are not too hard. Just cut them at the joint and remove the input from whatever with a six point socket. You will want to order some spare plastic clips and spend $70 at AB for the stainless replacements for the three rubber lines. I would also order the big nuts and star washers that hold on the rubber lines. Worth buying the whole set if you are keeping the truck, if not, just fine the little guy and replace him.
Old July 2nd, 2010, 10:46 PM
70 bucks? When did they get expensive? Last time I bought a piece of brake line it was like half that. Too bad I'm over here, I've got spares I could send you.
First of all, if you haven't destroyed the fittings, you could make that line with some tubing from the autoparts store, but you might be into it for more than 70 bucks by the time you buy a tube flaring tool and a cheap bender. And it takes some practice and fiddling to make a nice line.
Call some other suppliers, I'm sure RDS is cheaper than 70 for that line, and I'm sure lots of guys have some used ones.
I always replace with stainless. Even if you don't install the entire set at one time, its a worthwhile upgrade. Better to get it from ECR than Classic Tube - even though CT make them for ECR (or did previously) CT sucks, doesn't know their own inventory, and is annoying and unhelpful on the phone.
Old July 2nd, 2010, 11:06 PM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I have them for like $25 at AB but we are closed till Tuesday
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old July 3rd, 2010, 07:40 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Most autoparts stores rent the tools for free and brake lines are cheap. It's pretty simple to bend the lines by hand and flare the ends yourself.
Semper Fi!
Old July 3rd, 2010, 07:58 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Not that you have an endless amount of cash or space but I think a tube bender and flaring tool are two great additions to your toolbox...you won't need them every day but when you do, they are invaluable!
Old June 29th, 2013, 03:42 PM
I know this is an old thread...but anyone know the part number for this? Having a heck of a time finding it.
brake
Brake Line ? RoverChic Defender Technical Discussions 18 March 5th, 2007 05:45 PM
Hard brake lines! TwisteD90 Defender Technical Discussions 10 October 10th, 2005 12:12 PM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
Brake pedal is hard!!?? Vadim Defender Technical Discussions 9 January 25th, 2005 01:09 PM
brake line connections artm Defender Technical Discussions 0 May 7th, 2004 02:04 PM
