Handed springs - question - Page 2 - Defender Source
Old May 2nd, 2014, 10:01 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Originally Posted by jrose609 View Post
Zack, I'm assuming all this info is for the D90 and not the D110?
The HD110 rear springs I ordered from RN are the same part number. I have a definite lean. Are the rears supposed to be handed too?
Did you get this kit? http://www.roversnorth.com/ProductDe...e=3&eq=&key=it
If so, they're different numbers for all 4 springs.
Also, did you swap them before or after you did your LHD conversion?
Driver: NRC6388
Driver W/ leveling: NRC6389
Passenger: NRC7000
Passenger W/ leveling: NRC6904
Old May 2nd, 2014, 10:25 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
Driver: NRC6388
Passenger: NRC7000
Sorry, dude. I was wrong. I have the NRC6904 and NRC6389. They are not the same.
I did the swap before the LHD conversion. I need to swap the springs too.
Thanks for the help!
Old May 2nd, 2014, 10:30 AM
ssi19's Avatar
ssi19
scott
1995/D90
Originally Posted by Red90 View Post
You can't do either. They have closed and ground ends. They need to be properly heat treated or they will bend permanently the first time they compress. Can you measure the height of the springs while parked on a flat, level surface. That would help determine where you are at and what would be a good way to go. Why did you change springs in the first place?
I previously had old man emus w/ 2" lift. Wanted to switch back to standard height and softness with these new springs.
Trade OME HD springs for stock NAS D90 springs evilfij For Sale - Parts 8 May 3rd, 2013 12:10 PM
Parabolic springs or Original leaf springs Arrington Series Technical Discussions 5 June 1st, 2011 12:33 PM
Are front springs handed Cmikefly Defender Technical Discussions 1 March 30th, 2010 03:52 PM
NAS AC wiring question or call it a random wire question bjf Defender Technical Discussions 7 May 5th, 2009 09:58 AM
OME springs! TwisteD90 Misc. Chit-Chat 5 October 2nd, 2003 06:16 PM
