handbrake cable fitting? - Defender Source
Old September 26th, 2009, 09:08 PM
Hi All
Trying to fit the handbrake cable from the 300tdi/r380 setup. This is the type where the cable goes directly into the drum, as opposed to the large bracket on the side of the transfer box. Question is how it is supposed to fit at the seatbox end of the cable. There is a sort of traffic pylon shaped rubber bit that pokes through the metal of the seatbox but then it just flops around. It looks like it needs a metal sleeve around it or something to hold it in place. Does anybody here have a photo of this setup or have any experience making it work? Do I need a new handbrake lever as well? The clevis and all that fit just fine its is just the floppy end that is causing problems.
Working on this thing in the rain is kind of sucking. Put up a big blue tarp to purty up the neighborhood.
thanks
Dave
Old September 26th, 2009, 09:10 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
sounds like your lever is wrong..
Old September 26th, 2009, 09:13 PM
cabell's Avatar
cabell
Cabell Crowther
I think the newer style hand brake lever has an integral short (3/4"+/-) tubular jobby attached. I can take a pic tomorrow.
Old September 26th, 2009, 09:17 PM
so just out of curiosity does the NAS d90 have the right kind of lever for this cable?
thanks cabell...
Old September 26th, 2009, 09:24 PM
crown14's Avatar
crown14
Verticalscrote
thanks cabell...
sounds like it
Old September 26th, 2009, 10:15 PM
cabell's Avatar
cabell
Cabell Crowther
thanks cabell...
I'm sure it does, but mine is from a td5. Had to modify it slightly to work with my (lt77) cable.
Old September 26th, 2009, 11:04 PM
I used a DII cable on my LT230, I didnt have any issues...
Old September 27th, 2009, 01:07 AM
ok, so could you describe how the d2 cable fits? does your handle have a short tube where the cable pokes through?
Old September 27th, 2009, 09:06 AM
Abrooks's Avatar
Abrooks
Tony Brooks
IIRC, the handle I used had a sleeve thing (the "tubular jobby") on the back -- I removed it and it bolted right up (though I did have to adjust the cable a good bit.
Old September 27th, 2009, 11:26 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Dave,
Is there a reason you can not move your drum brake from your old LT230 to your new LT230? That is what I have done in the past, if I remember correct you just pull off the drum brake and there are 4 bolts that need to be removed.
Old September 27th, 2009, 03:18 PM
no threads on the side of the t-box to mount the early style handbrake bracketry.
Originally Posted by dave_lucas
Dave,
Old September 27th, 2009, 03:20 PM
Abrooks's Avatar
Abrooks
Tony Brooks
This is exactly the issue I faced -- best solution I could figure out was the d2 linkage and an altered handle.
Old September 27th, 2009, 03:26 PM
d2 has linkage? thoght that was cable directly into the drum like later d1 and defender
Old September 27th, 2009, 05:55 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Yes, that's what I meant, just use the d2 cable. That handbrake on that truck works like you wouldn't believe now.
brake
Speedometer cable mod for VDO - shop? mgrgpg Defender Technical Discussions 20 December 27th, 2013 11:57 AM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
Kickdown cable on ZF, DOH! RedRhinoProducts Defender Technical Discussions 0 November 13th, 2004 10:32 AM
Sub woofer cable? wicks Defender Technical Discussions 17 May 18th, 2004 09:51 PM
Installing new kickdown cable...anyone? P1CR Defender Technical Discussions 4 December 19th, 2003 01:15 PM
