hand winch questions - Defender Source
Old November 25th, 2004, 06:25 AM
chirider
George
Hi, i'm not ready to buy a electric winch for the d90 and already have a hi lift jack. do I need to buy a hand winch like the black rat or griphoist or does the hi lift jack do the same thing?
If you guys recommend a hand winch, where can i buy one? Thanks!
Old November 25th, 2004, 07:01 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
The hi-lift with the winch kit they sell will work as a hand winch.
Jimmy Buffett
Old November 25th, 2004, 09:48 PM
Hand winching SUCKS! Get a kinetic strap and always go out with at least 1 or 2 other trucks. The highlift works as a winch but it is a pain and a bit of work.
Old November 26th, 2004, 07:43 AM
flippedrover
Tyler
'94 D-90
I second what Mike said.
Jimmy Buffett
Old November 26th, 2004, 01:30 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
I have used a griphoist a few years ago. They are very prone to malfuntion when sand and dirt get into them plus I think they are $pendy
Save up and get an electric winch.
--Benjamin Franklin
Old November 26th, 2004, 04:23 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Even worse is something along the lines of a 2-ton "come-a-long". I've seen photos of them after splitting in half at the frame and the cable recoiling. Good for some things, bad for winching vehicles.
-Hans
My oil line fix
My 100k stopped odometer fix
Old November 27th, 2004, 01:33 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I've got a Tirfor hand winch, only used a couple of times in about 5 years of owning it. Bloody hard work.
BUT..... It's not how often you use it . it's how much you need it when you need it!
Mike Hammond
Old November 27th, 2004, 02:38 PM
redrover
Guest
Posts: n/a
What are the cables rated on these hand winches? I would be a little afraid of operating the crank when the line POPS! When my truck gets stuck it is usually really stuck. I switched to a 3/8 syn line for a extra marg of safety on my 9000. JP
Old November 28th, 2004, 10:57 AM
mikeslandrover
Mike Hammond
The cable is pretty thick, the Tirfor I've got is rated to 1600kg lifting so it's probably got a x5 to x7 safety factor built in and there's a shear pin in the mechanicals. It's bloody hard work and the only time I used it in real anger I double rigged it with a snatch block - double the pull or half the effort.
Mike Hammond
winch
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
Bulkhead Questions JimC Defender Technical Discussions 19 October 27th, 2004 01:00 PM
New differential questions... wicks Defender Technical Discussions 15 May 5th, 2004 11:39 PM
