Hand Brake Lever Removal - Defender Source
Old May 18th, 2014, 08:18 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
How the heck do you remove the hand brake lever? I've looked in all my manuals and online and all they say is remove the clevis pin. OK, did that, but how do you get the cable out? The cable passes through a rubber gromit thing but the cable eye will not pass through the gromit. Gromit will not pass back through the hole it is mounted in either.
Removing the seat box and this is the last thing holding it in.
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old May 18th, 2014, 08:25 PM
C391HAT's Avatar
C391HAT
Zach
86 110
It was a really tight fit but I was able to the grommet and cable through the seat box when I removed my seat box
Old May 18th, 2014, 10:31 PM
On my truck, the cable is attached to a steel strap that is bolted to the reverse side of the seatbox. Removing two screws from the seatbox disconnects the cable (and steel strap) from the seatbox.
Old May 19th, 2014, 06:23 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
It will pass through like a bad Mexican dinner. You can add a little lubricant if you like. Pull hard!
Old May 19th, 2014, 08:20 PM
moose's Avatar
moose
Brett
Sprayed it with slippery stuff and pulled... the eye slide through the gromit and the seat box is now free. Hopefully the cable will go back through without too much grief.
Brett
Ex-Mod 110 Tdi
Old May 19th, 2014, 08:50 PM
flananuts
Matthew
It will slide right back in no worries!
brake
Convert Right Hand Drive to Left Hand Drive aosias Defender Technical Discussions 17 March 8th, 2015 11:09 AM
Hand brake removal pdella Defender Technical Discussions 0 June 23rd, 2012 12:16 PM
Defender parking brake lever bcourtney Wanted 4 April 22nd, 2010 09:46 PM
Hand brake relocation discoinjapan Defender Technical Discussions 9 April 23rd, 2009 09:23 PM
Hand Brake Not Work Big D Defender Technical Discussions 5 April 27th, 2007 10:40 AM
