half shafts - Defender Source
Old August 22nd, 2012, 11:49 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
half shafts
Read somewhere that D90/Defender half shafts (10 spline) are stronger than the Disco (24 spline) is this true?? I did a search but couldn't find it again.
Checked the mircocat but the part numbers are all over the place, early Disco 1 is differnent, but the later Disco1 but is the same as the early 90's
When did the Disco change to 24 spline?
When did the 90's change to 24 spline? I am taken the reference to the spline count is at the diff?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old August 23rd, 2012, 10:25 AM
They are close to the same. The later model 24 spline shafts are necked done to almost the same diameter as the 10 spline. You can see Ashcroft test results here: http://www.ashcroft-transmissions.co...0halfshaft.JPG
Change to 24 spline was around 93/94.
Prior to that, though, you "could" get 24 spline in the rear of 90s and all 110s had 24 spline as well. Those shafts were all quite a bit stronger with little necking.
Old August 23rd, 2012, 01:06 PM
roverman2010
1985 LR 90 200Tdi
Thanks Red90
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Rear half Shafts / F&R Drive shafts ( stock ) Rugbier For Sale - Parts 2 September 24th, 2011 09:56 AM
Replacing rear half shafts and flanges.. DonFromWhitby Defender Technical Discussions 1 October 8th, 2010 10:00 PM
HD CV's and Half shafts muskyman For Sale - Parts 3 November 28th, 2006 03:32 PM
half shafts jimmy salmon Defender Technical Discussions 2 August 12th, 2005 12:04 PM
Stock diff, stock rear axle half shafts..... nilesj For Sale - Parts 5 October 15th, 2004 11:10 AM
