half shaft??? - Defender Source
Old February 20th, 2011, 05:49 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
half shaft???
As anyone ever experience something like this? I had to tighten the wheel bearing on the back of my 110. After the job done, I pull the half shaft out a bit to make sure I'll be able to put the O ring back. Pull a little too hard so the shaft got out.. Put it back but this time it when too much in. Try to pull it out again... IMPOSSIBLE! I'm freezing my butt out at -12 with that damn half shaft.. Someone please before I burn the truck help me!
Old February 21st, 2011, 09:17 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
Is it possible that once push too far an half shaft can be stuck? Can it go through the diff gear and need to be rotate to align back the splines? If no one suggest someone else I will brave the weather (-20) to get the rear diff pan out and try pushing it from the diff housing.
Old February 21st, 2011, 10:14 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Pull the other half shaft and use a long thin "poker" to push the shaft out, I think that will work on a Salisbury. The axles can't go in far enough to engage the other side gear.
If nothing else works weld a nut to the end of the halfshaft, thread a scew into it for a handle.
You cannot get to the halfshaft from under the diff cover.
Keith
Big, Red and ... aaa Red..
Old February 21st, 2011, 10:44 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
yeah I know I can't get it out from the diff. Want to push it from this location..
Old February 21st, 2011, 10:57 AM
LRover's Avatar
LRover
J. Michael McCaig
Try a strong magnet on a rod. I've used them to pull the broken piece of a half shaft out of a diff.
Old February 21st, 2011, 01:42 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
It ain't broken.. Just when in too much.. I drain the oil and i'm taking the diff pan out... Just might need to push it from inside the diff
------ Follow up post added February 21st, 2011 02:53 PM ------
well..... Took the other side out and with a steel bar I pushed it out... Job done!
Tom Wood Custom Drive Shaft: My story. :) Roving Beetle Misc. Chit-Chat 5 April 21st, 2012 01:37 PM
Stuck Half Shaft don Defender Technical Discussions 9 June 30th, 2009 11:16 AM
Rear half shaft play ... Retrofit Defender Technical Discussions 6 May 5th, 2009 10:44 AM
rear half shaft jimmy salmon Wanted 1 February 21st, 2008 12:54 PM
Help! Question about front rotor and drive shaft. DesertRat Defender Technical Discussions 5 October 24th, 2005 07:14 AM
