hail damage/ body repair - Defender Source
Old January 15th, 2007, 05:13 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
Hello, the bodywork on my D90 has a little ping or 2 on the flat surfaces. Is it true that dry ice can pop out such things? I heard that if you put dry ice on a small ding (with the surface to be repaired hot from the summer sun, preferably) the extreme cold will cause the ding to pop itself out.
Also, do those ding repair kits sold on JC Whitney,ect work? They consist of little sticks daubed with a super adhesive. You put it on a ding, let it sitck, and then pull it out.
Old January 15th, 2007, 05:42 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Don't wheel it do you? That said I'm not sure about dry ice since the dents in my truck are a little bigger than a hail dent. As for the dent wizard things they work on small dents ok.
Jimmy Buffett
Old January 18th, 2007, 03:30 PM
TheBlueDefender!
George Rogers
1995 D-90
If you can get to the back of the body panel, you can use a hammer and dolly on it. Put masking tape on the dolly so you don't scratch the paint and tap it out from the inside with the hammer. If you don't know what a hammer and dolly are, check out Eastwood.com to get an idea.....and then make your own. Piece of cake!
body, damage
Body Shop/Rover Repair Needed chrisconnie Defender Technical Discussions 8 November 8th, 2009 11:57 AM
Paint damage -what's the repair process paulb Misc. Chit-Chat 15 October 25th, 2007 09:47 AM
Body Damage waveridin1959 Defender Technical Discussions 20 June 24th, 2007 09:04 PM
Corrosion repair ideas mattarm Defender Technical Discussions 6 February 2nd, 2005 10:18 AM
Project D90--high miles, blown engine, bad trans, rust, body damage evilfij Wanted 5 November 12th, 2004 09:26 AM
