H4 retrofit lens/bulb combo = dim lights! - Defender Source
Old January 17th, 2005, 08:34 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
The setup:
I recently purchased a set of 'diamond-cut' H4 retrofit housings for my D90. The housing is relatively flat in the front, and there is a little 'umbrella'-like reflector in front of the H4 bulb (eg you cannot see the bulb from directly ahead). The bulbs are the standard 55/65W H4 with a distinctive blue tint to them (the look very blue when off looking at them, and the light they throw is close to white, but has a subtle blue hue).
The result
Is very poor! These headlights are much dimmer overall than my original sealed-beam halogens. In addition, I had to modify the housings to make them work in the LR light rings, and additionally, I have to crank the adjustments all the way "up" to get them to shine reasonably down the road in front of me (rather than lighting the road 5 feet in front of the D). It was a pain, and it seems all was for nothing.
Before I go about tearing these out, I was wondering about a couple of things.
1) is it possible I just have low-quality bulbs, which are not throwing enough light? Would different 55/65W bulbs perhaps make a difference? I don't want to fry the wiring with the 85/100W bulbs, and I haven't put myself to the time of running new wiring and relays yet.
2) is that reflector thing necessary? I need more light to project FORWARD and that reflector is in the way of at least some of the light (eg directly from the front of the bulb).
I am close to ditching these housings/bulbs, but then I have to admit to myself that I tossed away good money for crap gear
Old January 18th, 2005, 12:37 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Run direct power to them to diagnose if you would be happy with them when they have a better power source.
Search about adding relays.
JP
legend in my own mind
ht, lights
All lights seem dim johnpiero Defender Technical Discussions 5 December 12th, 2008 01:12 PM
Moving Dim Lights.... Eric Siepmann Defender Technical Discussions 3 November 22nd, 2004 11:46 AM
dash gauge lights very dim Marc Weinstein Defender Technical Discussions 15 October 17th, 2004 01:49 PM
Dim Instrument Panel Lights gearco Defender Technical Discussions 2 June 20th, 2004 11:29 PM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
