H4 Bulb Recommendations - Defender Source
Old June 16th, 2014, 01:55 PM
Whiesel's Avatar
Whiesel
Eric Williamson
LR-90 300 tdi
Not into LED or HID.
Hi guys, have searched, but looking for current opinions:
Cibie's and relay harness installed.
There is a load of stuff on the www regarding bulb quality, output and longevity which you may already have read, but looking for real life feed back from our community.
Looking for ligh output (NO BLUE) and longevity. (300Tdi so some vibration).
There are the +30, 40 50 etc and high wattage bulbs and much talk of reduced lifespan, hence your feedback may be lelpfull to us.
Regards
Old June 16th, 2014, 02:03 PM
Two recommendations:
1: Get a wiring harness with a relay
2: my bias having tried various bulbs is to stick with good old boring halogen. Hella does make a 100W halogen which is off road use only......
Old June 16th, 2014, 02:23 PM
Yes, the higher wattage bulbs have shortened life. Most H4 bulbs have a short life to begin with. It is kind of a crappy bulb type for the reason. The newer bulb types are all much better.
Try here for some of the longer life bulbs.
http://store.candlepower.com/lolirehebu.html
H4 retrofit lens/bulb combo = dim lights! jaherring Defender Technical Discussions 1 January 18th, 2005 12:37 PM
Side Marker Bulb Replacement Matt Klapmust Defender Technical Discussions 8 December 23rd, 2004 06:09 PM
Instrument light bulb / Sylvania replacement Mark M Defender Technical Discussions 2 November 17th, 2004 04:23 PM
Clock Light Bulb ronward Defender Technical Discussions 1 April 28th, 2004 04:13 AM
Side lamp bulb holder Neo Defender Technical Discussions 5 January 30th, 2004 05:07 PM
