Gullwing Windows - Defender Source
Old October 17th, 2016, 12:47 PM
DC_Bear's Avatar
DC_Bear
Bear
1984 Nintey
Gullwing Windows
I'm looking to replace my rear sliding windows with a single pane of glass, but I would really like to not give up the ventilation and access that comes with rear-sliding windows.
I came across these rear gullwing windows (come in glass as pictured or aluminum for higher security but you give up the visibility of course).
After I recovered from the sticker shock, I was further disappointed to learn that they don't have a partial-open position that might be safe / secure while driving. I know some trucks, SUVs and even mini-vans have pop-open rear windows that are secured with a latch but they barely open 1-2 inches.
I'd love to fabricate something like the above pictured gullwing window and marry it to a releasable limited opening latch for use while on the road (best of both worlds in terms of full-open ability and venting while in motion).
I'd love to hear if anyone else has come up with solutions to open/vent a solid pane rear window and or if anyone has a great idea on how to secure the gullwing window (or make my own for less $$)
Old October 17th, 2016, 12:55 PM
I have a gullwing which can be found as a small project thread. I've done several FIY fab attempts at saving money. I've learned that unless you have a full shop, most DIY fab jobs aren't worth the money invested. you end up crap and for a little more (all in) you'd having something professional and fit for job.
When you do the research, you'll find that the hardware alone is half the cost.
why do you need the windows to open only a little bit? what's wrong with sliding glass if you need them to only open a little?
if it's rattles that bother you, just get the gutter overhaul kit which will fix your issue.
Mark Kellgren
KM4BOR
Old October 17th, 2016, 01:07 PM
I rebuilt both my windows with the Garrison kit, new metal Masai latches and tracks from Zack at Rovers North for $175ish. Better than new with zero rattles.
Old October 17th, 2016, 07:21 PM
ghoregon
Greg H
1986 Defender 90 200tdi Ex-MoD
Dave, do you have the part numbers for the Masai latches and the tracks handy? I have the Garrison kit already, but like the idea of doing the tracks and latches at the same time.
Old October 17th, 2016, 07:39 PM
DC_Bear's Avatar
DC_Bear
Bear
1984 Nintey
I began looking for replacement options because my existing windows are: non-locking / latching, drafty, leak water, rattle, and un-tinted. As I started looking at the cost to re-gutter, lock, seal, and tint I began wondering if I was better off starting with a new kit (kind of to Overlander's point about custom fab being more trouble and often the same cost as buying a pre-made solution).
I'm looking at the Garrison kit (thanks, I had not seen this one) now but it would still require locks or latches to secure it. Further I need a seal for between the two panes of glass to stop water/wind and want to tint the glass. And after-market tint on the inside is never as good as factory tint built into the glass.
Old October 17th, 2016, 07:41 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Are the forerunner gull wings tinted? The are pretty slick and probably worth the asking price
Old October 17th, 2016, 08:34 PM
Bunyan's Avatar
Bunyan
Paul B
'88 Defender 110 3.5L V8
My buddy had them installed and says the hydraulics are pretty stiff and you can drive (or safari) with them open.
I do like the idea of being able to have them secured barely open for ventilation.
Old October 17th, 2016, 08:42 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
Couldn't you just put a removable limit strap on them? I'm planning on adding one to my 110 to access the fridge and recovery gear. I don't foresee a reason for me to only have them open a bit but I'm sure you could add some type of detachable cable.
Old October 17th, 2016, 08:47 PM
I'll find the parts number and post a link.
Old October 17th, 2016, 09:13 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The NAS sliders are very easy to open from the outside even when fully closed & latched.
Slide a metal yard stick (or any some-what stout metal strip) in between the 2 pieces of glass.
Push the latch in & hold it, while keeping it pressed, push the glass to the rear with your free hand.
Reach in and unlock the drivers or passenger door .... Done !!
Old October 17th, 2016, 09:42 PM
Mantec window guards
Mark Kellgren
KM4BOR
Old October 18th, 2016, 07:10 AM
DC_Bear's Avatar
DC_Bear
Bear
1984 Nintey
Agree. The idea of a limit strap seems simple enough but I was wondering if the hydraulics are stiff enough (sounds like they might be) to remain open at speed. The strap keeps the windows from opening more but might not keep them from slamming shut if a semi-truck (18 wheeler) roars by or you bounce over a bridge joint, cattle guard, etc.
If you find something suitable please do post a part # or link. That would be great.
Old October 18th, 2016, 07:37 AM
yes. the struts would keep it open at speed
Mark Kellgren
KM4BOR
Old December 22nd, 2016, 10:47 AM
spikemd
Ted
2001 P38, 2006 LR3, 1991 110
I'm looking at installing the front runner gullwing myself. It looks to me like they only open from the outside and are useful for accessing gear, not ventilation for rear passengers. I don't think you can open the gullwings from inside the vehicle. If you are thinking of a window that pivots out, you will need to fabricate hinges to keep them in place, but it shouldn't be difficult with a flat window. That being said, I think you will get more ventilation with sliding windows. I also came across the Masai windows that are similar to front runner but don't open as far which looks to me like accessing gear would be more difficult. My rear with be cargo only, no passengers.
window, windows, wing
Glass Gullwing Window Kit Sale Mybluett Vendors 20 December 16th, 2015 11:09 AM
Frontrunner Gullwing window box coffee Misc. Chit-Chat 7 February 4th, 2015 11:32 PM
Gullwing Doors SURVEYOR Misc. Chit-Chat 8 June 6th, 2014 07:42 PM
Gullwing window door Upgrade ini88 Misc. Chit-Chat 6 September 10th, 2012 03:07 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 12:14 PM
