Ground issue after new fuel gauge - Defender Source
Old June 10th, 2016, 10:42 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
Installed a new fuel gauge and everything went south... Everything worked fine before the new gauge, but after I installed and wired the new gauge the temperature in the madman ems started acting up... When I turn on anything electrical the temperature starts to go up and down. If I pull the ebrake then the temperature changes accordingly.. The ebrake isn't connected to anything O_o
Any Ideas??
Thanks!
Old June 11th, 2016, 05:46 AM
atpick's Avatar
atpick
Andy
1990 110
I had a similar issue of the temp increasing when I pressed the brake. Definitely a grounding issue. Started when I changed a headlight and ended two months later when it was traced to the right rear brake light. Get a multimeter and start tracing. Wires....
------ Follow up post added June 11th, 2016 03:48 AM ------
Also I believe the ebrake should activate a warning light. Check the main earthing points from the engine to the chassis. Download the wiring diagrams for model and you might be able to trace it to a specific area. I ended up having to have all my brake light connections soldered to help alleviate the problem.
Old June 11th, 2016, 06:06 AM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Pablo, this is the wiring diagram that I use for my Tithonus, if you don't have it.
ID:	151582   Click image for larger version
Old June 11th, 2016, 07:12 AM
PabloCocito
Pablo Cocito
Thanks!
------ Follow up post added June 11th, 2016 05:18 AM ------
Originally Posted by atpick View Post
I had a similar issue of the temp increasing when I pressed the brake. Definitely a grounding issue. Started when I changed a headlight and ended two months later when it was traced to the right rear brake light. Get a multimeter and start tracing. Wires.... ------ Follow up post added June 11th, 2016 03:48 AM ------ Also I believe the ebrake should activate a warning light. Check the main earthing points from the engine to the chassis. Download the wiring diagrams for model and you might be able to trace it to a specific area. I ended up having to have all my brake light connections soldered to help alleviate the problem.
My issue is when I do anything though... Brakes, ebrake, hazards, blinkers, wipers, etc...
And on top of everything it cranks slow... I thought it was the battery but it keeps doing it even after I installed a fresh new battery..
Could I have skipped a main ground when i swapped in the 200tdi?
Old June 11th, 2016, 12:49 PM
PabloCocito
Pablo Cocito
It ended up being the starter, luckily I had a spare and swapped it out... I learned a couple of new curse words in the process and I might have even cried... Should have dropped the downpipe i guess... But all is good now hahah
300Tdi intermittent start issue - starter or main chassis ground? nathanwind Defender Technical Discussions 30 February 21st, 2015 10:04 PM
Report of ride height & ground clearance gains after mods ontheway Defender Technical Discussions 5 June 7th, 2014 11:51 AM
Fuel gauge issue/question Tyler Wirken Defender Technical Discussions 3 May 6th, 2013 09:00 PM
No fuel to motor after new fuel lines-help Tyler Wirken Defender Technical Discussions 7 April 22nd, 2012 03:31 PM
Gauge Ground Photo?? Campbell Defender Technical Discussions 5 April 18th, 2010 08:18 PM
