Grinding Noise - Defender Source
Old April 30th, 2016, 07:41 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
Grinding Noise
Hi,
Occasionally when I stop in my 110 I hear a grinding noise from the rear. Goes away quickly and has only happened twice. Any ideas on why?
Ben
Old April 30th, 2016, 08:35 PM
Originally Posted by Ben Dutton View Post
Hi, Occasionally when I stop in my 110 I hear a grinding noise from the rear. Goes away quickly and has only happened twice. Any ideas on why? Thanks Ben
When you are slowing or when you are actually stopped?
Old April 30th, 2016, 08:40 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
When I am slowing. It has only happened twice. First time it went away as soon as I started again. Second time lasted a few seconds after I started again.
Old April 30th, 2016, 08:42 PM
Brake shoes?
Old April 30th, 2016, 08:44 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
It does sound like it - will get it checked out - thanks for your help.
Grinding noise in 5th at 70mph (80kmph) - 2.4 Puma Zone30 Defender Technical Discussions 2 April 21st, 2015 10:38 AM
Reverse gear grinding noise. TD5 JackDEF90 Defender Technical Discussions 3 October 22nd, 2012 03:49 PM
Grinding/weird noise 94 Defender NAS triple9music Defender Technical Discussions 10 July 13th, 2012 12:45 AM
2nd grinding? Synchro? Burke Defender Technical Discussions 25 January 28th, 2005 04:09 PM
Grinding into Second Gear? azdefender Defender Technical Discussions 4 March 9th, 2004 01:44 AM
» Defender Registry
95 RRC
WeBeCinYa
Murphy
NealK
Add your Defender
