Grinding into Second Gear? - Defender Source
Old March 7th, 2004, 04:20 PM
azdefender
Jim Beatty
Talking Grinding into Second Gear?
I am looking at purchasing a 1994 D90 (3.9 liter) with 72K miles on it-- It seems to be in good condition for the year and miles, however when shifting into second gear it "grinds" slightly--
If I am very careful I can shift into second without a grind, however under normal driving and shifting, second is the only gear that does this? It also does not really "like" going into second when downshifting-- It will do it but does not do it easily--
Is this "normal" wear for a D90 with that many miles--
Clutch was replaced less than 10K miles ago and it works fine-
What is the fix and is it expensive?
Are there other things/quirks that I should "beware" of or look out for on this year and model?
Is the '95 or '97 with the 4.0 engine a much better vehicle? and should I concentrate my efforts on finding one of those instead?
Best regards,
Jim
Old March 7th, 2004, 04:25 PM
azdefender
Jim Beatty
Oops forgot to mention -- Reverse on this transmission is up and to the left- (is that the LT77)?
Best regards,
Jim
Old March 7th, 2004, 09:17 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
Jim,
That IS the LT77. I have no experience with the LT77 but my R380's second is a bit slow compared to other manual shifts I've own. There is a thread a bit below this one that has more details on these trannys. The syncros are known to fail prematurely if not treated right. Using synthetic fluids and double clutching can help quiet things down, not to mention prolong the life of your gears.
Other than the usual tire-kicking that one would do when buying a used car, watch out for rust. These things rust like crazy, especially if buying it from the snow belt states. Goodluck, D90s are very fun vehicles!
Glenn
Old March 7th, 2004, 10:45 PM
azdefender
Jim Beatty
Glenn,
Thanks for the response-
I will take it to the dealer to have them check it out-- BTW --It is almost identical to yours (different tranny)- - Right down to the white paint-
Best regards,
Jim
Old March 9th, 2004, 01:44 AM
scot's Avatar
scot
Scot Yount
95 Coniston Green D-90 SW
I have a 94 and have had both transmissions. My old LT 77 had the terrible "CLUNK'' and had to be replaced. Watch out for that. My new truck came with the R380 and I immediately noticed the second gear problem which is most likely a bad synchro. I have been driving it for 4 years now without any problems despite the fact that the sychro is totally gone.
Wherever I go...there I am.
Gear ratios - 1995 NAS Defender? jam90 Defender Technical Discussions 3 February 19th, 2006 03:58 PM
Well, that explains the grinding I guess... Trigger Misc. Chit-Chat 2 November 25th, 2005 11:44 PM
LT230 Input gear again! Mike Hippert Defender Technical Discussions 17 June 19th, 2005 06:45 PM
Speedo Gear Removal 48vphantom Defender Technical Discussions 2 March 27th, 2005 02:51 AM
