Griding from drivetrain when i hit the clutch? - Defender Source
Old November 26th, 2005, 07:17 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
My D90 recently got exposed to a bit of rain with the top off and the center console out, and ever since, there is a grinding sound from the drive train whenever i press the clutch in. Any help? I can`t for the life of me locate the sound, but it sort of sounds like it is towards the center of the car.
Old November 26th, 2005, 07:26 PM
Bad news, it's when you push the clutch peddle in right? That would be the sound of the throw out bearing, it only costs about $20 or so but you need to seperate the tranns and the engine to get to it.
Old November 28th, 2005, 04:13 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
Yup, def the throw-out bearing if it's when you push the clutch in. How bad is the noise? Some small bit of noise is not unusual in higher-mileage cars....
Did you try pouring oil down the same places the rainwater went through?
Old November 28th, 2005, 04:54 PM
Nate - if you want we can meet up and I'll tell you if its the TO bearing.
It'll piss you off when you see the new bearing come out of the box - not nearly as irritating as the "plastic staple" though.
Old November 28th, 2005, 10:36 PM
oldscratchggf
nate
95 d90
the noise is pretty speradic, but when it does grind, it is pretty nasty.
I might take you up on your offer, Jim, once I am back in town towards the end of December.
Old November 29th, 2005, 12:01 AM
Did you take the D back to Boston?
Old November 29th, 2005, 01:59 AM
oldscratchggf
nate
95 d90
no, not yet. I don`t intend to do that until August or so. Still quite a few more projects before I feel that the truck will really be ready to make it all the way.
clutch
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
Drivetrain Failure d901560 Defender Technical Discussions 9 December 26th, 2005 11:31 PM
» Defender Registry
EXP-D1
MECA58
Bernie
SGandMT
Add your Defender
