Greese fittin an breather toob - Defender Source
Old December 29th, 2003, 05:45 PM
How many greese fittins suppose to be on da front drive shaft? I no there is 1 on da output side of da t-case but is der suppose to be 1 near da diff? I see some splines down there and a hole in the shaft where it appears there was a greese fitting but I am not positve. if the fitting has broken off will I have to get a new shaft or have to drill out the old one and retap?
also all this talk about diff breathers blah blah? where are they I am about 90% certain they are on the axle tube but are they? thanks people
Old December 29th, 2003, 06:47 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Thumbs up
On your rig the the front breather tube terminates in an upside-down "U" just to the left of your master cylinder. I believe there is a tube from your front & rear differential, transfer-case, and transmission, respectively. Although, the rear diff-breather terminates at the rear of the D90. I believe it's located on the drivers side just under the rear of the tub? Just to be sure you should check out Alan's set-up that he sells: (http://www.gulfcoastrovers.com/rover...ther/index.htm). It's nice . Hope this helps PP.
DJ
Old December 30th, 2003, 09:00 AM
Phillip, on my front DS there is 1 greese fitting on yhe shaft near the splines and one on each U-joint.
Old December 30th, 2003, 09:34 AM
coool. the splines near the diff?
Old December 30th, 2003, 11:49 AM
Yep.
diff breather tube size? Abrooks Defender Technical Discussions 4 November 23rd, 2009 06:07 PM
Fuel Tank Breather valve cbass Defender Technical Discussions 2 March 18th, 2008 03:09 PM
Breather valve for fuel tank cbass Wanted 0 March 18th, 2008 01:01 PM
New style breather tube!! 48vphantom Defender Technical Discussions 1 August 7th, 2005 09:05 PM
axle breather install CHRIS C Defender Technical Discussions 6 March 22nd, 2005 07:59 AM
