Greasing bushings - Defender Source
Old July 23rd, 2004, 08:24 AM
ronward's Avatar
ronward
Redsrover
None - sadly
Greasing bushings
Hi all, I have OME Nitro shocks on my 90 and the rear passenger shock has a bad squeak that seems to be coming from the top polly bushing. I plan to apply some Kendall superblue all purpose packing grease to the bushing on Saturday. Will this deteriorate the bush prematurely? TIA
Old July 25th, 2004, 11:30 PM
I would do it. A new bushing is cheaper than your sanity listening to the squeek & knowing where it is coming from!
With that said, try some high grade RTV spray (silicon spray). It may be kinder to the bushing than some petrolium bases grease.
bushings
Bilstein shocks and bushings themaxx Defender Technical Discussions 3 October 29th, 2006 04:07 PM
Slotted Radius Arm Bushings -- Opinions? LRNAD90 Defender Technical Discussions 7 June 19th, 2006 11:37 AM
DAP bushings jorge Defender Technical Discussions 5 April 18th, 2005 08:39 PM
Body bushings - poly or factor rubber?? jaherring Defender Technical Discussions 15 February 10th, 2005 06:42 PM
Rockware Trailing Arms w/ good bushings lwg For Sale - Parts 1 January 9th, 2005 04:06 PM
