Grease or Heavy Duty oil in CV Housing - Defender Source
View Poll Results: Grease or Heavy Oil in Swivel Pin Housing
Heavy Weight Oil 11 50.00%
Recommended Grease 10 45.45%
Other 1 4.55%
Voters: 22. You may not vote on this poll
Old June 17th, 2008, 02:32 PM
TND90's Avatar
TND90
Keith Allen
94 d90 ST
Justed wanted to get a broader idea of which form of lubrication is best for the swivel pin housing. I have read the existing threads concerning this matter and it seems that some prefer a thick oil, such as EP90, and others along with Land Rover recommend the grease. I just finished rebuilding the swivel pin housing and want to make a good choice the first time.
Look forward to hearing everyones comments.
Keith
"There is no normal life Wyatt, there's just life."
Doc Holliday
Old June 17th, 2008, 02:47 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I think you will find this one to be highly opinionated, but since you asked. I prefer Oil in the swivels. To me (assuming the owner checks the levels regularly), the oil provides better ability to 'get into' all the tight areas and lubricate properly, and it is also much easier to flush out contaminants if necessary (water crossing gone bad, etc).
In the case of Defenders, I also like it better because that was the original engineering specification for lubrication. For a long time there were never any issues with oil as a lubricant, it was just that Land Rover got tired of paying the dealers hours worth of labor to change out leaky seals, so they came up with the grease, and eliminated more seal replacements from the warranty costs budget.
I run Redline's 75W140 in the swivels (along with the diffs and t-case), I'm sure others will have many opinions to share.
~Scott T.
'95 D-90 ST - AA Yellow
Old June 17th, 2008, 03:41 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Originally Posted by jeepeytr
IRedline's 75W140[/URL] in the swivels (along with the diffs and t-case), I'm sure others will have many opinions to share.
Another for oil. You can drain it.
I'm not an oil expert but I think you are supposed to use 75w(or 80w)-90 in all the gears.
Old June 17th, 2008, 04:38 PM
Oil. I always remove the seal between the swivel and and axle so that they share oil. With oil, you know when they are leaking BEFORE you decide to go wading. With grease you get to find out after..... In proper condition, the swivels should not leak.
Old June 19th, 2008, 01:24 AM
TND90's Avatar
TND90
Keith Allen
94 d90 ST
Thanks guys,
John, what type of oil do you run in your front diffs with the seal off? Any negatives to removing that seal? I was actually wondering about doing that exact same thing. Is the seal there because Land Rover specified different oils for the diff and swivel pin housing?
Doc Holliday
Old June 19th, 2008, 06:02 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
If you mix oil 50/50 with the grease you get both the improved lubrication of the moly grease and the ability to drain it after sitting stuck in the mud for hrs.
Matt Browne
Old June 19th, 2008, 12:45 PM
Originally Posted by TND90
Thanks guys,
A 75W90 synthetic, usually Redline. With the range of temperatures I see up here, a wider range of viscosity is a good idea. Rover does not specify different oil (or didn't).
There is no downside. In Australia, they have been doing it since the 70s. You should overfill a bit as the swivel levels are higher than the axle, but I suspect it really does not matter. On the initial fill, make sure you fill the swivels as well.
Old June 19th, 2008, 04:14 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
What He said...
I do this too..
Keith
Big, Red and ... aaa Red..
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
Bearmach Springs Heavy Duty... h2eater For Sale - Parts 0 July 9th, 2004 12:40 PM
GBR heavy duty drive flanges jorge Defender Technical Discussions 2 February 29th, 2004 11:51 PM
