Grease on water pump gasket? - Defender Source
Old February 10th, 2012, 09:49 AM
peachyracer's Avatar
peachyracer
Peter Stolz
My wifes '94 D90 POE #1500
I'm fitting a new water pump and the manual says to "smear a small quantity of grease on both sides of the new gasket...." Regular grease on a coolant fitting? Just thought a little grease would get into the coolant and not be ideal.
Pete
Old February 10th, 2012, 10:03 AM
Naplm00
Matthew
Don't use grease. Use RTV, it will help the gasket stick in place and also help in keeping it from leaking. You only need a slim coating on both sides of the gasket.
I prefer to use the ultra black permatex RTV on everything, or Hondabond HT. I think that hondbond HT is the best non-shrinking/drying sealant on the market but it is very expensive.
Also to keep your waterpump bolts from rusting or leaking you can use a threadsealant on them like:
http://www.permatex.com/products/Aut..._with_PTFE.htm
The pic below is from some subie website but demonstrates the point, I tend to use less then this amount on the mating face and on the other side of the gasket.
Old February 10th, 2012, 10:55 AM
I always use Permatex Aviation Form-a-gasket on paper gaskets. It is available at most auto parts stores and I think its less than $8.
http://www.permatex.com/products/aut..._Sealant_a.htm
Old February 10th, 2012, 11:17 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Us old timers just use a little grease or vaseline. You should barely be able to feel it on the gasket, put it on both sides.
Old February 10th, 2012, 05:55 PM
peachyracer
Peter Stolz
Lots of opinions for sure. I did get some of that thread sealant for the bolts. Thanks for that because I couldn't find any Loctite 572 per the manual. I got another opinion on the gasket issue from the guy at the parts house, but I don't really trust it for certain because he said to use Threadlocker blue on the bolts, and I'm pretty sure that's not right. Anyway, he said to use Indian Head Gasket Shellac. Never heard of it, but I gets it's pretty old school which is always cool. Still have to decide what to use, but thanks for the suggestions.
Pete
Old February 12th, 2012, 11:59 AM
Fwiw I use blue loctite on the water pump bolts. Any bolts that go through a cooling passage I use liquid pipe thread sealant, but loctite or right stuff work just as well. I think you are over thinking this a little bit.
Old February 12th, 2012, 10:46 PM
peachyracer
Peter Stolz
Yeah, I'm prone to do that sometimes. My daughter put it in in high school shop class last year with very little guidance from the shop teacher so the gasket leaks a little. It's also a warranty replacement, so I don't want to have to open this thing up again. This truck has many other areas of need that I'd like to get to. Thanks for the help.
Pete
gas, water, water pump
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Water Pump Help!!! Dfndr90 Defender Technical Discussions 14 May 3rd, 2005 11:51 AM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
Water pump replacement mwmcgehee Defender Technical Discussions 6 June 2nd, 2004 12:00 PM
