Grease is the word - Defender Source
Join the Defender Source Community Today
Old September 1st, 2016, 06:17 PM
javelinadave's Avatar
Grease is the word
I'm installing new bearings when I do a disc brake conversion. What to the consensus of wheel bearing grease. AutoZone stocks Mobil 1 Synthetic and Lucas Red N' Tacky. They have about the same specs. At this moment I'm planning or running wet hubs but I may stay stock.
Thanks and here is the mandatory Grease video:
Old September 1st, 2016, 06:37 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Both are very respected products. In this instance you couldn't go wrong with either.
Black Rhino Lives Matter
Old September 1st, 2016, 06:50 PM
I just use the "bucket" of Valvoline red grease you get at Napa, and has been fine. FYI...if you're running wet hubs, grease is really a bit of a moot point since it'll get all mixed up with the 90W anyhow and won't last/stay long in the bearings anyhow (I do still recommend you pack them up even if running wet hubs, can never have enough lube!).
Old September 1st, 2016, 09:03 PM
I doesn't really matter.
Old September 1st, 2016, 09:24 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I use std. dyno stuff. I have 2 types.
One can I have, and it's old, looks like dull snot & seems almost fibrous as I pull a wad of it out of the can.
The other is dark, almost black and very smooth and sticky.
I always put some extra in there thinking that maybe centrifugal forces & heat will give a little extra to the bearings.
Old September 1st, 2016, 10:00 PM
Thanks! The first tub I picked up said not to be used with vehicles with disc brakes. I'll either get the tub of Mobil 1 or hit up NAPA in the morning.
Old September 1st, 2016, 11:35 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
You got me thinking about the disc brake thing, checked both if mine neither are for disc brakes, thousands of miles later and I just put all new discs on a few thousand miles ago.
Well, here's Google's disc brake grease search
https://www.google.com/#q=disc+brake...bearing+grease
Old September 2nd, 2016, 07:02 AM
Parrie's Avatar
Parrie
Parrie Willette
1989 D90 P/U
I've been using Lucas X-tra heavy duty grease...most auto stores carry it as well as Walmart. Ike Goss swears by SIG-3000 grease but I couldn't find a local supplier.
Update on white arkonik 110-- final word havens51 Misc. Chit-Chat 28 February 3rd, 2016 01:44 PM
My First Book - Please Spread the Word! Wolf Fabrication Misc. Chit-Chat 6 December 13th, 2011 04:47 PM
swivel pin housing - grease or oil or both? cgalpin Defender Technical Discussions 27 March 9th, 2007 09:16 AM
A word document on Importation paulb Support & Suggestions 3 April 11th, 2005 04:25 PM
Spread the word... Tawayama For Sale - Vehicles 27 April 1st, 2005 08:15 AM
