Gosh darn head gaskets - Defender Source
Old June 3rd, 2011, 06:22 PM
It looks like the head gaskets on the 4.2 are leaking again. It's been less than a year and under 4000 miles. When the engine is cold it's pushing a little bit of coolant thru the exhaust. After warm up it seems OK.
I don't know what to do next. I used the very expensive stretch bolts and composite head gaskets which I figured would be the last of it for a long while.
I don't know if I should try going another half turn on all of them, pull the whole shiz apart again and put in the same stuff all new, or go back to the steel gaskets and regular bolts. I know the heads are straight and the block is true.
I don't drive it all that much, but I would like it to be a bit more reliable.
OK stop laughing.
Old June 3rd, 2011, 06:41 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Do not worry at all, V8 are a breeze to work on
You can re-torque head bolts in 10 mns on a Tdi
- Charles Eames
Old June 3rd, 2011, 08:30 PM
Thanks for that Julien. I have been into this engine quite a few times.
Old June 3rd, 2011, 08:44 PM
dchapman
Daniel Chapman
1999 D1
Gee whiz, Beaver. I wounder what Eddie Haskell would do.
Old June 3rd, 2011, 09:25 PM
Haskell would have an H2.
Old June 3rd, 2011, 09:34 PM
is there a plug that is a bit cleaner than the other ones?
Old June 3rd, 2011, 10:06 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I have had 2 different 3.9's in mine and had the heads done probably a total of 5 times. They are not my friend.
Are you sure you don't have a slipped sleeve? In the end, both blocks I had slipped a cylinder liner. When that happened in the second block I said some unpleasant words and then converted to a 300TDI (which then blew a head gasket because the jackhole I bought it from didn't torque two of the head bolts when he put new heads on it).
I should probably just convert it to electric.
gas, gaskets, head gaskets
3.9 motor w low miles & head gaskets RoverDude For Sale - Parts 0 May 4th, 2011 04:42 PM
Anyone done the head gaskets on a Disco II? Turbofan Defender Technical Discussions 3 June 18th, 2010 06:25 PM
head gaskets or screw it? huck1974 Misc. Chit-Chat 1 May 4th, 2007 09:16 AM
4.6 block, which gaskets? vesparover Defender Technical Discussions 0 March 6th, 2006 07:17 PM
