Good Vibrations - Defender Source
Old May 22nd, 2004, 10:19 PM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
Good Vibrations
Guys:
I just installed a 3" lift in the D and I am getting some significant vibes. I assume I need to swap out the drive shafts for some Double Cardons or maybe even some multiple double cardons. Can anyone make any specific recomendations and/or recommend a good source? Right now I am looking at AEDOFAB. Has anuyone dealt with them before? As always, thanks for any help,
Doug
Old May 22nd, 2004, 10:28 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Hey Doug
I installed the same lift a few months ago and I went with the DC-drive shaft from GBR. It was about $600 I believe? Anyway, it's easy to install and I haven't had any abnormal driveshaft vibrations since. I only elected to install a DC up front and kept the OEM in the rear, but will eventually replace that one too. Hope this helps & let me know if you've any other questions.
DJ
Old May 22nd, 2004, 10:30 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
I second Great Basin Rovers. A tried and true solution.
Chris von C
[/size]
Old May 22nd, 2004, 11:54 PM
dnewman9's Avatar
dnewman9
Dennis Newman
*SOLD*Conniston 97 NAS 90
From what I have read we can simply swap a DiscoveryII front driveshaft instead of buying a custom unit for 3 inch lifts?
I have been looking at lifts and found the DII driveshaft relatively inexpensive. I have held off of the lift however due to the fact I thought the majority of the vibes were from the rear driveshaft not the front?
So, am i safe to assume i could do the lift and front shaft swap only untill I can afford the rear driveshaft?
Old May 24th, 2004, 10:41 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I lifted my 90 3" and use Tom Woods drive shafts, $378. Strong, uses spicer ujoints. No more vib. from rear. Then I installed Rovertym front radius arms to correct steering geometry. Got vibration from front so installed Tom Woods driveshaft with no cardons and it fixed the problem (I think it was longer than stock). Cost less than the double cardon.
Old May 24th, 2004, 10:50 AM
I don't know if you get everything lined up good you should be Ok with the stock drive shafts. I have around 4" and stock front and rear, no vibs but I do have to replace the U joints around once a year if I'm not to ruff on them. I think Randy (tdiguy) had problems with the CV shafts, but I don't rember.
Old May 24th, 2004, 09:12 PM
Doug_Paoletti
Douglas P. Paoletti
'94 D90
Thanks for the feedback. I'm going to give GBR a call tomorrow.
Vibrations again.. sflash868 Defender Technical Discussions 3 April 22nd, 2006 11:24 AM
Watching some good Rover porno chrisvonc Misc. Chit-Chat 13 January 10th, 2006 11:25 AM
Light Weight needs a good home Kevin For Sale - Vehicles 2 February 6th, 2005 01:01 AM
So where's the pics of some good hard rock action Dave? Mike Hippert Misc. Chit-Chat 0 January 26th, 2005 07:51 AM
Good thing he had the jack! PT94D90 Misc. Chit-Chat 3 October 10th, 2003 02:10 PM
