good times... won't start... - Defender Source
Old February 4th, 2008, 06:00 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
Drove around all day on Saturday with no problems, works awesome... didn't touch it on Sunday then this morning I kick on the Webasto at 6:00 am to warm up the engine at 6:30 I hop in to start it up: glow plugs seem to cycle just fine but then I switch the key to start and nothing happens. No click, no whiny engine, nothing.... fortunately I have another car I can drive to work but what should I check once I get home? I did try sticking on one of those cheap jump batteries to see if I had run the battery down but that didn't seem to make any difference.
I DID try searching the archive but I couldn't find anything that I thought was relivant... help please...
Old February 4th, 2008, 07:38 PM
Check the starter relay. You can bypass it by putting it in neutral, key in the run position, and touch a hot wire to the small spade connector on the solenoid. If it starts turning over, you starter relay is bad.
hth
charles
Old February 5th, 2008, 05:04 PM
bharris's Avatar
bharris
Brad Harris
So here's the follow-up:
I got home with the intention of checking this, put the key in the ignition and it started right up with no problems at all....
I'm really glad it started but now I'm afraid of getting stranded somewhere
any further suggestions??? Maybe buy a new relay just in case that's what it was?
Old February 5th, 2008, 07:36 PM
It could be a number of things. A relay isn't a bad idea to get because it's the same relay used for a few other things I think (and it's cheap). You can also carry some wire and if it happens again, do the hot wire trick.
But it could also be bad grounds. One way to confirm that is take jumper cables and properly ground it, and alos get 12v right to it that way too.
But you still could be left stranded before figuring it out. Get AAA if you don't have it already - well worth it. Maybe try only drive it when being delayed an hour or so wouldn't be the end of the world until you figure it out?
charles
Old February 5th, 2008, 10:00 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Not sure of the steps involved in a 300 Tdi conversion, but if your ignition switch is the same, this could be a possible culprit. If it happens again, try wiggling the ignition switch and see if that changes anything. Not sure how expensive this part is. I saw it happen once before on a '94 NAS V8, but can't recall the symptoms besides the fact that it wouldn't start. Maybe someone can chime with more indications of a bad ignitition switch, or just start searching for "ignition switch".
-Neil
start
D-90 stuck in Park, Won't start. HELP!!! brianosaurus Defender Technical Discussions 9 December 12th, 2007 09:45 AM
won't start andyrad Defender Technical Discussions 6 March 2nd, 2006 07:38 AM
Anybody know of a good shop in Cali ? skibigwest Defender Technical Discussions 2 February 13th, 2006 11:54 PM
is DAP-INC good on customer service airbornrover Defender Technical Discussions 12 January 27th, 2006 08:54 PM
WTB - d90 - Good to Great Deal. uzj100 Wanted 1 July 15th, 2005 12:54 PM
