Good Source for Vibration Isolators? - Defender Source
Old July 23rd, 2015, 11:29 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Hello All,
Anyone have a good source for small vibration isolators? I want to use them to mount a Ready Air compressor. Prefer cylindrical style with studs extending from each side. Need 5/16-3/8" studs preferably, and would like the isolator to be no more than 1/2" deep. Tall order?
~Scott T.
'95 D-90 ST - AA Yellow
Old July 23rd, 2015, 11:49 AM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I used ones from a 300tdi air filter unit
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old July 23rd, 2015, 12:03 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Can sell you these pretty cheap, not sure the exact specs on them
http://www.roversnorth.com/ProductDe...795&type=0&eq=
Old July 23rd, 2015, 12:17 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Here's the Genuine, which should be similar if not identical
Old July 23rd, 2015, 04:47 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Wow, Thanks for taking the time to send the detailed specs, much appreciated! I'm going to see if I can track down isolators with the larger studs first, but they make work if I cannot. Thanks Again..
~Scott T.
Old July 23rd, 2015, 04:49 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I wasn't busy
I may try this myself when I install my compressor. I'll let you know how that goes...
Old July 23rd, 2015, 09:37 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
I just used rubber grommets for mine and it works perfectly.
Old July 23rd, 2015, 10:37 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
How thick are the T-case isolators? In a pinch, I went to the local NAPA and they eye matched my old ones. I assume they have assortments of isolators there.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old July 24th, 2015, 03:57 AM
psykokid
Jake
1997 Disco
McMaster has a decent selection of these as well.. McMaster-Carr
Old July 24th, 2015, 09:29 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
EBay has just about anything you'd want, cheap.
Old July 25th, 2015, 10:44 AM
amazon as well
FS: Rubberized Spring Isolators (4) fleabus For Sale - Parts 2 April 13th, 2009 10:45 AM
F/S New OME 751's, 762's Towers, Retainers & Isolators Paul Grant For Sale - Parts 0 August 5th, 2008 11:19 AM
Has anyone installed rubber spring isolators from Exp Exchange? WI-ROTTIE Defender Technical Discussions 4 May 31st, 2007 03:54 PM
Rubberized Spring Isolators/ Shock Tower Securing Ring? oldscratchggf Defender Technical Discussions 10 October 2nd, 2006 05:44 PM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
