Good recommendation for transmission repair in NJ - Defender Source
Old July 6th, 2011, 08:09 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
I have a 94 D90 3.9L r380 that needs the synchros replaced in 2nd and 3rd gear. Anyone have good experience with shops in NJ that do good work?
Old July 6th, 2011, 08:18 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Maybe give www.landroversvc.com in Flemington a try
Old July 6th, 2011, 09:06 AM
Naplm00
Matthew
vinnie at roverspeacialit might know someone
Old July 6th, 2011, 09:25 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Call Lee at 201 385 0333 He is in Dumont, NJ. You will probably have to leave a message.
It appears that their former partner made this bogus page http://www.importspecialist.net/ him and Vinne (in Paramus) had some sort of business together and they have now split.
I would recommend Lee's work. For reference call Land Rover in Paramus and talk to the parts counter and ask who they recommend for you tranny work on a Defender....
Also check these guys out. http://www.europeanexchange.com/ they get a lot of work from dealerships.... prices are fair. There are many people on the board here that could help you drop the transmission if needed.
Old July 6th, 2011, 12:17 PM
flananuts
Matthew
Thanks. I'll check into it. I need someone to look at the transfer as well, seems I can only get it into 4wL, but not too sure on that.
Old July 6th, 2011, 12:24 PM
tjfslaughter
thomas
Burbon
where at in NJ are you?
Old July 6th, 2011, 02:35 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
I think Red Bank NJ
John C.
Old July 8th, 2011, 02:51 PM
flananuts
Matthew
Sorry for the delay, I'm in Red bank area, currently in Toronto
Old July 8th, 2011, 03:10 PM
tjfslaughter
thomas
Burbon
Dumont is about an hour north. There are guys that are in Bridgeport that can help as well.....
Old July 8th, 2011, 03:15 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
There is Forgein Cars of Monmouth in Fair Haven that could point you in the right direction.
Old July 10th, 2011, 08:52 AM
flananuts
Matthew
Thanks for the assistance.
------ Follow up post added July 10th, 2011 09:10 AM ------
One quick question for the guys on this thread. I've only had my D90 for about 2 months. Is this truck in 4wd H all the time, or do you transfer from 2wd into 4w H or 4w L? Interestingly enough I'can't find an answer to this and I don't know any other Defender owners in the area to ask. It might make sense as to why I can get to neutral and 4wd L.
Old July 10th, 2011, 11:17 AM
Truck is in 4H all the time ... their is no 2WD ... unless you pop the half shafts out!
You can lock the diff between front and back ... that's when the light on the dash comes on ... you shouldn't drive on the road like that ...
Old July 10th, 2011, 12:25 PM
flananuts
Matthew
On the transfer case, what direction would I shift? I appreciate the input. ?
Old July 10th, 2011, 01:05 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
You want High Range, Unlocked for most driving. If memory serves that means the shifter is back and to the right. Make sure the locker light on the dash goes out.
Old July 10th, 2011, 01:34 PM
karlusmagnus
Karl O'Donoghue
71SiiA
Matthew, try downloading the manuals, to familiarize yourself more
http://www.landroverweb.com/landrove...rover-manuals/
Old July 10th, 2011, 02:14 PM
flananuts
Matthew
Thanks for the link. I've been through the pdf workshop manuals and never thought to select the one that says Defender TD5. Very helpful indeed!
Old July 10th, 2011, 05:18 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I'm right in Rumson and dont know a ton but would love to help if I can. And airborne is right over in Eatontown. Might need to get a small gtg one night.
Old August 25th, 2011, 05:15 PM
flananuts
Matthew
Hey Don, sorry fo the delay, sounds great and Tom at Foreign Cars is great. Did a great job replacing my clutch master and slave cylinder, tie rod assembly. If you see a 94 yellow D90 with fiberglass lid and safari cage around town, be sure to honk My D90 saved my tail last Sunday when I unsuspectingly hit a major flooded section of 34 in Wall. I love my truck
transmission
Door Panel Repair? boshea Defender Technical Discussions 3 January 17th, 2006 04:13 PM
Corrosion repair ideas mattarm Defender Technical Discussions 6 February 2nd, 2005 10:18 AM
how to repair hard top crack? chirider Defender Technical Discussions 8 December 14th, 2004 08:11 AM
good trade? jperakis Misc. Chit-Chat 4 March 25th, 2004 04:23 PM
what's a good pricing guide for D90's? januconn92 Misc. Chit-Chat 4 January 11th, 2004 01:53 PM
