Good Auxiliary Heater for diesel defender? - Defender Source
Old January 29th, 2013, 12:22 PM
gomotomoto
adam
Has anyone had luck with an inexpensive auxiliary heat system for their diesel defenders?
Old January 29th, 2013, 12:32 PM
That is a big question......
You can replace the stock heater with a larger and more efficient one. I can point you to some options.
You can add a second heater. Again lots of choices.
You can add a diesel fired coolant or air heater, both are a bit pricey but great to have.
On a 90, adding proper insulation and sealing is the best place to start and is adequate down to -30 or so with the stock heater.
Old January 29th, 2013, 12:36 PM
gomotomoto
adam
I assume that the 12V options are sh!t?
Old January 29th, 2013, 12:41 PM
Correct. There is not enough power available from electricity to make any difference.
I personally have a very serious system, over three times the output of the stock heater. Much more than needed at any temperature.
defender, diesel, heater
Massive clearout of stuff - all parts located at my place in the UK globallandrovers For Sale - Parts 3 May 2nd, 2012 07:16 PM
The "Increase your heater output" thread Overlander Defender Technical Discussions 25 February 28th, 2012 06:42 PM
Good Condition Defender Bulkhead rgrrvr Wanted 4 January 15th, 2012 09:00 AM
heater box cables on an 80's Defender 90 sonoronos Defender Technical Discussions 5 August 22nd, 2011 11:24 AM
Free Defender...to a good home, history of abuse, loving owner needed nathanwind The Flea Market 2 August 21st, 2011 10:54 AM
