GM gen III - Page 8 - Defender Source
Join the Defender Source Community Today
Old August 28th, 2015, 09:00 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got the mount fabbed up for the Rakeway carrier bearing, it replaces the existing doubler on the back of my front 3 link x-member. Once installed I have just enough room to get a TW shorty shaft between it & the t'case.... fingers crossed !
Also, got the ECM mount made up.
Slow progress but getting there... might have the motor running by Christmas
D100 5.3 LS powered truggy under construction....
Old September 7th, 2015, 02:30 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Working on the throttle cable, used the Chevy Silverado outer with the LR EFI inner.... should look stock once I solder a new nipple on the throttle body end.
Clutch piped up using some M13x1mm banjo's & dash 4 hose.
Old September 25th, 2015, 10:08 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got the main fuel tank pump upgraded to a high pressure, hi-flow type to suit the Vortec along with the Earl's -5/-6 adaptor and a new connector.
If your doing the same make sure you get the correct hose, it's 'in tank' specific and to SAE J30R10 spec. Regular hose won't last as the outer layer isn't designed for constant immersion in the fuel.
Next to get the tanks plumbed up and we're one step closer
Old October 5th, 2015, 09:01 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Hybrid throttle cable done.... looks stock !
Old October 8th, 2015, 12:09 AM
CDeWan
Clay DeWan
5.3L beastie
Ok . Just a quick testament to Nick's meticulous engineering after 1 year 6 month my gen III has clocked 16,000 and no engine or fit and finish problems whatsoever. I did manage to kill the 4l60e as a rock ware belly guard which prevented a proper amount of air flow over the transmission and towing another 90 for 2500 miles across country caused the failure during the first 3,000 miles of the install. The BW 1339
Quatra Trac T Case has it's down sides as it does not like the harshness of a Detroit locker witch will be pulled as soon as I can find a 4:11 rear LSD set up and the chain is definitely not as robust as the gear to gear LT230 set up. Regardless this is by fat the best modification the truck has experienced. I have got tons of Hps on demand and still grin ear to ear by mashing the pedal as I watch a waward jeep disappear in his attempt to catch a rover. This truck will also tow a double axle car carrier with no problems. If I had to do it all again , I would start with a Markiw engine swap before any other mod and go from the inside out in building a truck. This mod is not for the low mileage garage queen but is essential if you want to have a realizable everyday vehicle
Old October 8th, 2015, 09:39 PM
3rovers's Avatar
3rovers
Dennis Yard
1993 NAS D-110 #55
Clay,
Glad to hear you are still enjoying "my" truck. I think it had about 213K miles when I got it from the fellow in Long Island, NY, then put a few on it myself. I do miss the open top driving most all year round in San Diego.
Dennis
Dennis Yard
Land Rover Club of San Diego
1993 NAS D-110 #55 (GNUTRUK)
2004 Disco II (DSCO DOG)
Old October 13th, 2015, 02:39 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Just cause it looks so cool..... dash 6 fuel hose installed
Old October 16th, 2015, 12:38 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Needed to get a replacement starter motor for my '99 Vortec, old one was the long & short bolt type, new is the later 2 long type. If you have the same swap you'll need another long bolt and it's part #11610787.
Name:	LS starter.jpg
Old November 4th, 2015, 11:44 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Fuel, starter & charging cables run onto the motor using adel clamps
Old November 8th, 2015, 11:41 PM
Way of Life's Avatar
Way of Life
1988 Defender D110
Hi Andy, reading the hell out of this build.
You got me hooked on this build for my truck.
Just got a 2010 D130 Body and now have to ship it home.
This the set up I want just not sure 6sp man or auto.
Lots of information Thanks
Land Rover Defenders. 65 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy.
Old November 9th, 2015, 12:00 AM
madcowdungbeetle
Carter
I bet that P-pump will blow the guts outta the rover steering box.
Old November 9th, 2015, 12:01 AM
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Nope. Runs great.
Old December 28th, 2015, 10:11 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Fixed the crappy looking fuel lines with some 180 degree fittings
Old December 28th, 2015, 10:32 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Nice
Old December 28th, 2015, 10:35 PM
skitzy's Avatar
skitzy
Nick
91 D90 2.5NA doing LS Gen IV Thing
Nice and clean.
Old December 31st, 2015, 01:35 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Just a quick follow up on the fuel lines, one of the guys on another forum pointed out (after I posted this pic) that you can flip the fuel rails by trimming the plastic tabs off the plenum to get the connections pointing backwards again on the drivers side.
Would save a few $ on the 180 degree fittings....
Old January 31st, 2016, 01:20 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Link to my separate build thread on schedule 40 exhaust manifolds....
http://www.defendersource.com/forum/...lds-67840.html
Old June 26th, 2016, 10:53 PM
Landy_Andy's Avatar
Landy_Andy
Andy
As I've got the front fenders all bolted back on, now to work on the 'little' things, like rad hoses and the rest of the plumbing.
The top two hoses will be connected with a 6" x 1.25" dia aluminium coupler.
Old July 10th, 2016, 09:13 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got some more work done on the exhaust manifolds... added the opposite end cylinder pipe to stabilize the outlet pipe.
Then added the middle pipes.
The drivers side will need a couple more 45's to offset it away from the frame rail to get the V-band coupling in.
Old July 13th, 2016, 07:51 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got my exhaust manifolds all completed... just need ceramic coating now. Well pleased with how they turned out
Iphone 8GB 2nd Gen For Sale Rugbier The Flea Market 28 December 16th, 2009 09:51 PM
FS: 1st gen 8gig iPod Touch mpodgorski The Flea Market 7 December 16th, 2009 07:03 PM
Misc parts (D1 and gen purpose) Ray_G For Sale - Parts 5 October 5th, 2008 09:11 AM
FS: 30g iPod Video & 8g iPhone 1st Gen mpodgorski The Flea Market 3 August 7th, 2008 08:37 AM
New here. A gen question re: Rovers Emerson00 Misc. Chit-Chat 26 December 20th, 2006 11:53 AM
