GM gen III - Page 7 - Defender Source
Old May 1st, 2015, 04:13 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by rankar View Post
Andy that's awesome. Did you go with the gallo 12 or gallo 24 setup?
Haven't got a clue what your asking ???
Old May 1st, 2015, 04:29 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Obviously the Gallo 24!!! That thing hauls A$$! ;-)
http://www.metacafe.com/watch/an-P4f..._brian_part_2/
Old May 1st, 2015, 07:05 PM
Landy_Andy's Avatar
Landy_Andy
Andy
2 Fast 2 Furious (2003): Recruiting Brian Part 2 - Video
Ha ha !
Old May 3rd, 2015, 03:25 PM
CDeWan
Clay DeWan
5.3L beastie
Got around 8k now on the gen III. Going strong. Since this set up uses the BW1339 t case I am getting what is called chain slap on hard take off. Nick and I had to use a used morse chain back when we did the swap as the Chinese chain was comoing apart that nick had less A 1000 miles on it. There is a company in Tacoma, BJ's off-road (I Believe) that sells a US made chain. I am also running a locker in the rear and going to switch to a LSD as I think the locker is a lot harder on the hp/t-case combo. No complaints whatsoever on doing this swap. It is awesome!
Old May 5th, 2015, 12:47 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Added anti-crush tubes to the relocated t'case mounting holes here :
http://www.defendersource.com/forum/...ame-61888.html
Next to install the drive line & engine.
Old May 8th, 2015, 01:26 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Major milestone reached.....
Good clearance to the front x-member too, so that won't need to be reworked.
Well pleased
Old May 8th, 2015, 08:51 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Wow, nice Andy. Definitely the gallo 24 setup
Old May 8th, 2015, 09:11 AM
Landy_Andy's Avatar
Landy_Andy
Andy
BS..... gallo 36
Old May 13th, 2015, 09:09 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Looks like it missed this one.... the Hooker headers are going dump right onto the clutch slave cylinder....
Need to review options now... quickest is to swap to an internal slave but I'll have to mod the NV as the early ones were external only or find some other headers that'll fit.... or custom st/st headers... ???
Old May 13th, 2015, 09:29 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Are those ports symmetrical? Can you put a right side exhaust manifold on the left side and have the outlet at the front of the engine?
Old May 13th, 2015, 10:13 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Yes, but then the passenger side would dump into the AC compressor. Going to see if I can loan some different OEM ones before I do anything else... plenty of other stuff to be working on whilst I work this out.
Old May 13th, 2015, 12:54 PM
UnfrozenCaveman
Keith Armstrong
Various
Well, that's what I get for thinking out loud
Old May 13th, 2015, 02:13 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Don't feel bad... I compleatly missed it in the first place. Won't work on the drivers side either, would dump into the steering box. One option is to fit a pull type slave cylinder or swap to an internal slave but that's not what I really want as it makes long term maintenance difficult.
Will ponder this for a while... Plenty more to work on.
Old May 13th, 2015, 08:19 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Maybe end up with a sch'd 40 log manifold... least there cheap
Name:	Log manifold.jpg
Old May 18th, 2015, 11:40 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Been hunting around the interweb looking at many pictures of exhaust manifolds and found these on a NV install in a Jeep....
Looks like they'll clear the engine mounts & have an email into Sanderson to get the dimension of the flange outer edge to the block. If it's tight can always cut it off & fit a V band couplings... might do that anyway cause they look cool
Old May 18th, 2015, 09:17 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got a reply back from Sanderson, they tell me the distance is approx. 5" as per this picture.
So, looks like they'll work ok, will prob get them bare... cut off the flange and add a short bend to get the 'V' band horizontal. That should make the 2 into 1 merge under the bell housing nice and neat.
Old June 4th, 2015, 11:07 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got the dash 6 tube adaptor fitted today on the PAS pump return line. Just waiting for my hose & fittings to arrive now.
Old June 27th, 2015, 12:36 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got my Russell -6 hose & fittings last week, made up the PAS hoses.... just the hydro assist to install now.
Happy I took the opportunity to move the engine & drive line back 1" from stock, I can squeeze in a pair of the Spal mid size fans now
Old August 12th, 2015, 02:59 PM
Landy_Andy's Avatar
Landy_Andy
Andy
This is the revised ECU mount, waiting for cut parts to arrive now
Got a hand full of serp belts & found one that fits nice with the Goatbuilt ALT & PAS mounts. It's a Dayco #5060805
Got the loom about finished, just need a few colors for the dash gauge sensors.
Old August 13th, 2015, 03:01 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Been throwing round ideas in my head on the front & rear drive shafts, I was thinking of swapping out the t'case front & rear flanges to 1350 U joints, like this (pic's borrowed from Pirate4x4) :
However, that'd be adding quote a bit of cost just for the Ford 9" pinion yokes & machining to make fit plus the 1350 drive shafts are 50% more expensive than 1310's.
So, remembered that Philion used a split shaft on his comp truck with a Rakeway centre bearing :
So, that's the way I'm doing it, got a drawing of the bearing assy from Rakeway & will make up a mount to bolt onto the back of the existing 3 link x-member.
I'm thinking that with solid 1310's and not running over 35/37" tires we should be good... I guess time will tell !
Oh.... drool time over those Spidertrax axles........
Iphone 8GB 2nd Gen For Sale Rugbier The Flea Market 28 December 16th, 2009 08:51 PM
FS: 1st gen 8gig iPod Touch mpodgorski The Flea Market 7 December 16th, 2009 06:03 PM
Misc parts (D1 and gen purpose) Ray_G For Sale - Parts 5 October 5th, 2008 08:11 AM
FS: 30g iPod Video & 8g iPhone 1st Gen mpodgorski The Flea Market 3 August 7th, 2008 07:37 AM
New here. A gen question re: Rovers Emerson00 Misc. Chit-Chat 26 December 20th, 2006 10:53 AM
