GM gen III - Page 6 - Defender Source
Old November 18th, 2014, 08:41 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Advance Adaptors NV4500 bell housing & slave cylinder mounting bracket arrived today... Nice quality & well packaged.... Another step closer
Old November 20th, 2014, 02:11 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Originally Posted by Landy_Andy View Post
Starting to look at my fuel system for the 5.3 install, currently have duel saddle tanks with the early RaRo return type in-tank pumps & electric changeover valve. Looking at the pump specs it appears the ~35psi isn't up to the task. Was thinking of installing a swirl pot and inline pump to feed the engine.... Anyone gone this route ?
You can install those if you replace the pump with the one in the BOM. The LS needs higher fuel pressure than LR EFI. You will need to address the supply and return lines with the changeover valve.
Old November 20th, 2014, 02:56 PM
Landy_Andy's Avatar
Landy_Andy
Andy
The changeover valve is a Pollak and does the lines & fuel gauge sender units, it's rated at 65psi so should be good. A version is used on the Ford 'F' series trucks with duel tanks if anyone wants to find one in the bone yards.
http://products.pollakaftermarket.co...r-driven-valve
Was searching last night & found this aftermarket replacement pump that'll fit my tank setup :-
http://treperformance.com/i-6317858-...1987-1995.html
So, am thinking that I can swap a pair of those in and save having to use a swirl pot setup. When I get closer I'll order one up & test it out.
Old November 20th, 2014, 10:03 PM
TMWTP's Avatar
TMWTP
Jon
1989 One Ten
I've been talking to Matt @ Rockware about doing this to a 110. If I could find the right one to buy, we'd be rolling on it. I'll be looking at a aluminum block, Gen IV, auto with an Atlas. Keep the info coming! It looks killer so far.
'18 TRD Pro Tacoma
'17 Discovery (wife's dd)
'88 110 under the knife
'83 110 - FOR SALE!
Old November 21st, 2014, 08:21 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
The LT230 is a really nice T case and you get to keep the stock drive-lines in the stock location why swap to an Atlas?
Old November 21st, 2014, 08:53 AM
TMWTP's Avatar
TMWTP
Jon
1989 One Ten
Fair question. Don't know much about it. I've had two Atlases in the past, so I'm familiar with them. I'm not married to the stock axles so I was planning on 1-tons or 9". Figured I could sell the complete 110 driveline to offset the cost of a much stronger domestic unit so parts are cheap, easy, and plentiful.
'18 TRD Pro Tacoma
'83 110 - FOR SALE!
Old November 26th, 2014, 07:57 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Started the pruning of the 5.3's loom using the excellent instructions on lt1swap.com, with using the NV4500 you don't need VSS or the hi/lo inputs and trans wiring. Makes for a very simple loom once done... Nice for fault finding if ever I need to
Old November 27th, 2014, 01:22 AM
Landy_Andy's Avatar
Landy_Andy
Andy
When using the truck plenum reversed, the loom still has to enter on the drivers side of he engine. So, the IAC & TPS connectors will need to be extended about 10". This also makes it possible to use the GM throttle cable if you salvage a throttle pedal to use the end of it on the LR one
Old December 15th, 2014, 06:22 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Picked up a used NP241C as a donor for my crawler box, not bad for a case of beer
Old December 25th, 2014, 04:57 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Christmas day shopping.....
Here are the part numbers for the NV4500 clutch install :
#12557583 - GM Clutch pilot bearing (SKF #6302VSP43)
#11569956 - GM Flywheel bolts x 6
#12561465 - GM Clutch cover bolts x 6
NFW1050 - Sachs 4.8/6.0 flywheel (doesn't need a spacer)
#TBC - Sachs 10 spline, 11" clutch kit for SBC
This should work with an OE bell housing or the Advance Adaptors one (from what I've read over multiple sites)
Old December 26th, 2014, 08:16 PM
Landy_Andy's Avatar
Landy_Andy
Andy
#NFW1050 - Sachs 4.8/6.0 flywheel (doesn't need a spacer)
#K5552-03 - Sachs 10 spline, 11" clutch kit for SBC
To add :
1377-C - Throwout bearing
178N - Throwout arm boot (not sure if this will fit the AA bell housing yet)
#12558718 - Inspection cover
#12561536 - Inspection cover
Old January 26th, 2015, 10:43 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Ended up ordering a LuK clutch kit #04-049 (as per AA sell in their kit), same spec as the Sachs #K5552-03 but was cheaper including delivery etc.
Old January 29th, 2015, 11:27 PM
Landy_Andy's Avatar
Landy_Andy
Andy
First half (literally) of my Behemoth underdrive arrived today, very pleased with the quality of the machining. More parts due next week... Can't wait to start getting my drive line in the truck, then the 5.3
Old February 5th, 2015, 03:32 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Made a start building up the Strong box underdrive.... very nice quality
Old March 9th, 2015, 05:14 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Monster box installed... will build a triple stick shifter once it's back in the truck.
Old April 26th, 2015, 01:31 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got the old engine mount zipped off & the new ones tacked in ready for trial install as soon as I get my head bolts & Camaro water pump.
Flipped the hi/lo lever around on the LT230 to make the cable shifters fit better.
Dry assembly of the Goat Build PS pump & Alt mounts, might need to do a few mods for the Camaro water pump.... will see.
Seem to have gained an extra pedal !
All for now !
Old May 1st, 2015, 11:12 AM
Landy_Andy's Avatar
Landy_Andy
Andy
First test fit
Gonna need to go back an inch to accomodate the Allisport rad.... but we know that already
Just enough clearence for the oil pan to the 3 link but will prob swap it out for a Camero one once things are up & running. Will be ok for the time being.
Old May 1st, 2015, 12:19 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2516
So pretty!!! Want to touch! Must resist! ;-)
Very excited to see this run! Good job.
"Barry is correct!"
Old May 1st, 2015, 03:07 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Thanks.... lots of stuff still to do though
Old May 1st, 2015, 04:09 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Andy that's awesome. Did you go with the gallo 12 or gallo 24 setup?
Iphone 8GB 2nd Gen For Sale Rugbier The Flea Market 28 December 16th, 2009 08:51 PM
FS: 1st gen 8gig iPod Touch mpodgorski The Flea Market 7 December 16th, 2009 06:03 PM
Misc parts (D1 and gen purpose) Ray_G For Sale - Parts 5 October 5th, 2008 08:11 AM
FS: 30g iPod Video & 8g iPhone 1st Gen mpodgorski The Flea Market 3 August 7th, 2008 07:37 AM
New here. A gen question re: Rovers Emerson00 Misc. Chit-Chat 26 December 20th, 2006 10:53 AM
