GM gen III - Page 4 - Defender Source
Join the Defender Source Community Today
Old June 19th, 2014, 03:50 PM
Originally Posted by nmarkiw View Post
This setup is for sale. 2002 5.3L (LM7) Gen3, 2006 GM NV4500, adapter to LT230. New intake/injectors/thortle body(cable operated), new Painless harness, ECU, p/s pump. Engine has 98k miles, trans has the same. PM me if anyone is interested.
Think you need to put this in the classifieds.
Old June 22nd, 2014, 02:37 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Got a '95 gearbox last week, found it had previously cracked in the side of the case & been repaired...
Seems that this is a common issue from ones that have been in 1T diesel trucks. Something to watch out for if your looking for one. Other issues to watch for are the synchro's on 3rd & 4th and the 5th gear nut backing off causing the main shaft to get damaged. That issues also seems to be common on diesel trucks, read something about the torque pulses from the Cummins backs it off.
Other than that it looks to have been refurbished at the same time as the repair was done so hopefully I won't need to put too much money into it.... and I only paid $300 for it so can't complain too much
Next to find an early bell housing or I have to spring for the AA one.
Name:	NV4500 cleaned.jpg
ID:	97330   Click image for larger version
Name:	NV repair.jpg
D100 5.3 LS powered truggy under construction....
Old June 22nd, 2014, 02:42 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Slight trimming on the tail housing required.
Nic, have you done this yet.... will trim mine b4 I media blast & paint the tail housing.
Old June 29th, 2014, 05:14 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Any new pics ?
Old June 30th, 2014, 10:15 PM
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
There you go!
ID:	97886   Click image for larger version
Old June 30th, 2014, 11:53 PM
Landy_Andy's Avatar
Landy_Andy
Andy
There you go!
Thanks.....
Old July 1st, 2014, 10:52 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Anyone else looking to undertake this conversion... or just me at the moment ?
Old July 25th, 2014, 11:13 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I'll not start a new thread for my gen 3 Vortec install to make searching easier...
So today, I mostly pulled the complete drive line & cleaned up the engine bay.
ID:	99456   Click image for larger version
Old July 25th, 2014, 11:44 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
1957 107 wagon, 94 arles St, 95 RRC
I'll not start a new thread for my gen 3 Vortec install to make searching easier... So today, I mostly pulled the complete drive line & cleaned up the engine bay.
that is a seriously cluttered bay!! You should really rethink the hole rover thing if you can't keep it a little cleaner! (Sarcasm you could eat off that shiot)
Old July 27th, 2014, 05:41 PM
nmarkiw
Nicholas Markiw
Andy,
Sorry to say that the LS truck oil pan won't clear the 3-link and the NV4500 won't clear the cross member.
Old July 27th, 2014, 10:39 PM
The Dro
Dro
1988 Ninety
Wow. Just saw these pics. That's a clean frame and bulkhead
Old July 27th, 2014, 11:11 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Andy,
Umm... I have 4" of lift and extended bumps. I guess once I get the motor & trans in we can drop it to full bump & see how things fit... I have drawings for different 3-link x-members & I could always dry sump it, that'd fix that issue.... thoughts ?
All add to the fun
Old July 28th, 2014, 09:30 AM
dry sump would be totally overkill but really cool!
Old July 28th, 2014, 11:09 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Nothing wrong with overkill! ;-)
(p.s. Love following you progress. Great work.)
Old July 28th, 2014, 10:51 PM
nmarkiw
Nicholas Markiw
All add to the fun
You should be able keep the oil pan off the 3-link with the correct length bump stops.
I had a Safari Gard 3-link. I ended up smacking the oil pan. Went back to traditional radius arms.
Old July 29th, 2014, 04:53 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Had a look around, a lot of options for swapping the pan out too so either way it'll get sorted.
Gave the NV a good clean up, left it alone inside as oil looked ok and it had been refurbished fairly recently. Fitted a grub screwed 5th gear nut as a matter of precaution & buttoned it all back up after a fresh coat of paint.
Will see how it goes once the trucks back on the road.
ID:	99653   Click image for larger version
Old August 12th, 2014, 09:16 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Andy,
Was looking back through my old 3 link build pic's and found this one of the x-member in my truck...
And comparing to this from... from here http://www.defendersource.com/forum/...ad.php?t=27138
I think I should be OK, Nic ?
Old October 19th, 2014, 10:17 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Had to get the shop cleared up ready for winter so.... bolted a few bits up
ID:	105324   Click image for larger version
Old October 19th, 2014, 10:43 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Looks good Andy...I am so glad I don't live that far north for the winter season!
Old October 19th, 2014, 10:48 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Snows on it's way..... ski hill got a nice white top this last week.
Iphone 8GB 2nd Gen For Sale Rugbier The Flea Market 28 December 16th, 2009 09:51 PM
FS: 1st gen 8gig iPod Touch mpodgorski The Flea Market 7 December 16th, 2009 07:03 PM
Misc parts (D1 and gen purpose) Ray_G For Sale - Parts 5 October 5th, 2008 09:11 AM
FS: 30g iPod Video & 8g iPhone 1st Gen mpodgorski The Flea Market 3 August 7th, 2008 08:37 AM
New here. A gen question re: Rovers Emerson00 Misc. Chit-Chat 26 December 20th, 2006 11:53 AM
