GM gen III - Page 3 - Defender Source
Old October 8th, 2007, 11:17 AM
JBOD77
Jonathan
1995 D90 ST Beluga Black
This is where I'm supposed to write something witty and funny; or something.
Old April 21st, 2014, 01:47 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by nmarkiw View Post
I would stay away from the 4.8L. Unless you plan to build one.
That's what I was thinking, no pick-a-parts here, nearest is 3hrs drive away. So, getting a good selection of used engines is hard.
Old May 2nd, 2014, 11:16 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Found this on eBay.
http://www.ebay.com/itm/251518250514...84.m1423.l2649
Dodge NV4500, 23-spline only. These guys are into 4BTs. No provision for transfercase shifter or LR mounts. Guess you could use the single Dodge transmission mount and a custom cross member.
I always wanted to put a 4BT in a Defender.
Old May 2nd, 2014, 12:57 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Found this on eBay.
Yuck.... oil burners
Old May 2nd, 2014, 03:09 PM
keep the 4bts in the bread and chip trucks
Old May 2nd, 2014, 05:29 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Ok, ok. I get it. You guys aren't interested in smokers.
Old May 3rd, 2014, 01:18 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Was looking through Buck's thread on Pirate, doesn't look like there will be any clearance issues with the NV...
Name:	Bucks Adaptor.jpg
Old June 2nd, 2014, 07:50 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Some useful info here for mounting up older NV4500's to a LS/gen3
http://youtu.be/RCGl5HbrUeE
Old June 10th, 2014, 06:51 PM
Landy_Andy's Avatar
Landy_Andy
Andy
More useful tech in fitting a later bell housing to the earlier ('93-'94) trans...
http://www.pirate4x4.com/forum/chevy...lave-swap.html
Old June 12th, 2014, 09:09 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Nv4500
The GM NV4500 arrived. Looks like it will fit. Slight trimming on the tail housing required. Same place as on the 6L80e.
Hydraulic clutch will make it easy to plumb to the Defender clutch master.
Still need to measure the shifter position and trim the tail housing.
ID:	96614   Click image for larger version
Old June 13th, 2014, 01:49 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Looking good Nic, what's the distance from the front seat box mounting brackets on the frame to the centre line of the shifter tower ?
Old June 13th, 2014, 09:53 AM
Landy_Andy's Avatar
Landy_Andy
Andy
I think looking at the installed pic, if anyone uses an early ('93 - '94) box with the original bell hsg the throw out arm/slave cyl might be in the way of the drive shaft as it sticks out just below the starter. In that instance using the Advance Adapters kit or a modified ('95 onwards) hsg with the internal slave cyl (as yours has) would be the way to go as both exit on the drivers side. Looking at the cost of bell hsg's on Ebay & the cost of getting the machining done the AA kit is prob a better option & you get the external slave cyl too for easier servicing.
Old June 13th, 2014, 01:04 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
The GM NV4500 shifter appears to be 3" forward from the LT77 location.
Old June 13th, 2014, 01:18 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
...see photo.
Old June 13th, 2014, 03:58 PM
Landy_Andy's Avatar
Landy_Andy
Andy
What's the distance between the shifter center lines (in red), I have an auto at present so no existing gear stick to reference off.
Thanks.....
Old June 13th, 2014, 04:10 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Thanks.....
8 inches.
Old June 13th, 2014, 07:06 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Thanks... what's the height of the gear stick stub relative to the top of the hi-low shifter housing, just need to make sure it'll fit under my custom dash.
Cheers
Name:	NV Shifter.jpg
Old June 13th, 2014, 07:47 PM
Landy_Andy's Avatar
Landy_Andy
Andy
More useful info if going Advanced Adaptor bell housing route :
AA Part #712576 bell housing
AA Part #715535 hydro clutch slave cylinder bracket
Napa Part #NCF 73117 Clutch Slave Cylinder
Napa Part #UP 38559 MC to Slave hose (don't know if this'll work with the LR master cyl though)
Old June 15th, 2014, 10:57 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Cheers
5.5 inches
Old June 16th, 2014, 09:30 AM
Landy_Andy's Avatar
Landy_Andy
Andy
5.5 inches
Thanks Nic.... should fit ok with my dash, might need a dog legged stick but that's an easy sort. Hopefully have my box here by the end of the week
Old June 19th, 2014, 02:44 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Too much stuff in my shop!
This setup is for sale. 2002 5.3L (LM7) Gen3, 2006 GM NV4500, adapter to LT230.
New intake/injectors/thortle body(cable operated), new Painless harness, ECU, p/s pump. Engine has 98k miles, trans has the same. PM me if anyone is interested.
Iphone 8GB 2nd Gen For Sale Rugbier The Flea Market 28 December 16th, 2009 08:51 PM
FS: 1st gen 8gig iPod Touch mpodgorski The Flea Market 7 December 16th, 2009 06:03 PM
Misc parts (D1 and gen purpose) Ray_G For Sale - Parts 5 October 5th, 2008 08:11 AM
FS: 30g iPod Video & 8g iPhone 1st Gen mpodgorski The Flea Market 3 August 7th, 2008 07:37 AM
New here. A gen question re: Rovers Emerson00 Misc. Chit-Chat 26 December 20th, 2006 10:53 AM
