GM gen III - Page 2 - Defender Source
Old April 15th, 2014, 02:07 PM
CDeWan
Clay DeWan
5.3L beastie
just put 2500+ miles on this set up 5.3 Gen III, 4 speed auto and BW T-case (out of a Quadro-trac set up circa late 70s Grand Cherokee) No issues with engine and tranny, just a leaky t-case which I will get after.
Old April 15th, 2014, 02:29 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
What kind of mileage did you get towing?
Old April 16th, 2014, 09:34 AM
CDeWan
Clay DeWan
5.3L beastie
8-10 mpg's.
Front towing D-90 has a rovers north rack filled with bikes, boxes etc - creating drag. 33 x 12 tires 3 inch lift, 4:11 gears. No salt flat racer by any means
Towed 90's front axle was on a tow dolly adding weight and also has a rack on it. No items were stowed in the towed vehicle and I kept only a few gallons of gas in the tank to minimize ass wobble.
I did down shift liberally which on any grad would not only hold speed but accelerate the vehicle.
I would say average speed was around 60mph. The composition of the highway (asphalt vs. concrete) and wind direction limited my speed due to the towed vehicle getting ass happy and wobbling from side to side. Fixed with a quick step on the brake and followed by an acceleration to a speed that would not induce ass wobble.
Engine started with no problem ever - no check engine lights, idle when warm was around 500rpm. Just nice and quite.
I am going to get a new accelerator cable as mine has probably been on the truck since new and is stretched. I sometimes did run into a problem with a downshift as the stoppers on the accelerated cable would not allow the TPS to read the correct % to kick down 2 gears for hill climbing. Nick this is what we worked on that one night to adjust the kickdown parameters. I think a new cable will provide more flexibility in adjustment.
I will keep the post updated on mileage once I start using the truck as a dd and unload everything.
------ Follow up post added April 16th, 2014 10:35 AM ------
Nick,
The only other question that I would have is that if I go back to an LT 230 from a BW what are your recommendations for speedometer functioning? Is there a box that will convert the cable speed out of the LT230 to a digital signal to the VDO speedo?
Old April 16th, 2014, 09:54 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
8-10 mpg's.
Nick,
You would install the GEMS/Bosch VSS (YBE100540) onto the LT230 and wire into your VDO speedo using the existing VSS wiring.
Old April 16th, 2014, 10:25 AM
8-10 mpg's.
There are stock Land Rover speed transducers that connect directly to the LT230. Used in Disco 1s and TD5 Defenders.
Old April 17th, 2014, 08:33 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Test fit 4L60E
Well, it doesn't fit. The pictures show my adapter with the trans case rotated 3 degrees.
This will take some work. A new adapter and shaft.
ID:	93249   Click image for larger version
Old April 17th, 2014, 11:28 PM
pendy's Avatar
pendy
jim pendleton
89'd90
If it were a merc diesel you would just cut the corner off the pan. Kidding.
I think the marks adapter version for the 400 gm transmission gets more length then what I am seeing there but hard to tell from pictures.
Name:	2nd disc 148.jpg
legend in my own mind
Old April 18th, 2014, 12:50 PM
Landy_Andy's Avatar
Landy_Andy
Andy
So really might as well just buy the Marks 4L80E/LT230 adaptor then... ?
Old April 18th, 2014, 12:52 PM
pendy's Avatar
pendy
jim pendleton
89'd90
That might be the case for the Gen III stuff
Old April 18th, 2014, 02:54 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Yes, just be aware that the 4L80e is much longer and with that adapter it will put the t-case back 5+ inches.
Old April 19th, 2014, 11:35 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Umm..... guess I'll be waiting a couple of yrs till the gen 4's start to find their way into the junk yards then...
Just snagged this off GP's FB page..... looks interesting... finally had to switch from LR to GM for decent power / $$ ratio
Name:	GP truck.jpg
ID:	93295   Click image for larger version
Old April 19th, 2014, 01:21 PM
pendy's Avatar
pendy
jim pendleton
89'd90
But when you look at the Marks adapter it keeps the diff lock shifter in the same place and moves the transfer case back. Of course the engine will have to move forward some as well. It is a more difficult conversion then the Gen IV drop in style you have worked out. But the Gen III conversion with this Marks adapter should be pretty straightforward. In fact it has been done many times around the world would be my guess.
Old April 19th, 2014, 01:47 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Classic BW
Looks like the Classic Borg Warner will fit with some minor trimming.
...or I could move it back 1/2"
Old April 20th, 2014, 03:08 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Where would that put it mount wise without any additional spacer assuming the transfer box stopped in the normal location ?
Was just watching first couple of episodes again of Engine Power again, where they built a cheap junkyard 4.8....
http://www.powernationtv.com/episode...ls-tech-part-1
http://www.powernationtv.com/episode...ls-tech-part-2
Would the BW transfer box stand up to ~390bhp at the flywheel ? If so... seems a nice budget orientated way to go rather than a 3.9/4.6 LR build.... thoughts ??
Old April 20th, 2014, 03:42 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
This would locate the BW in the stock location and put the engine in the same location as my Gen IV build. You could use all the brackets from the Gen IV build. Same Y-pipe,... Still needs a different adapter shaft. 4L60e is 27 spline, 6L80e & NV4500 are 32 spline.
I would stay away from the 4.8L. Unless you plan to build one. The 5.3L Gen3 is 295HP, the Gen4 is 320HP stock. That BW should hold up to these figures. I definitely wouldn't try pushing 400HP through it though.
I have a 2002 5.3L Gen3 sitting in my shop looking for a project. New intake, new injectors, new Painless harness, ECU... Was thinking about a NV4500 behind it. I need to test fit it anyway.
Old April 21st, 2014, 11:53 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Thanks Mark....
Snagged a few more pic's from GP's FB page.... guess if you have deep pockets, Quaife to the rescue
ID:	93380   Click image for larger version
Old April 21st, 2014, 01:10 PM
That is the Quaife 6 speed manual box, I believe. Kind of a different topic?? Only 8950
http://quaife.co.uk/news/high-streng...r-transmission
Old April 21st, 2014, 01:25 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Nice. Too rich for my blood. Makes the NV4500 sound more attractive.
Old April 21st, 2014, 01:26 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I guess so... but deff need deep pockets !
Old April 21st, 2014, 01:40 PM
Certainly. And better gear ratios for the normal off roader, IMO.
http://www.high-impact.net/nv4500.htm
Iphone 8GB 2nd Gen For Sale Rugbier The Flea Market 28 December 16th, 2009 08:51 PM
FS: 1st gen 8gig iPod Touch mpodgorski The Flea Market 7 December 16th, 2009 06:03 PM
Misc parts (D1 and gen purpose) Ray_G For Sale - Parts 5 October 5th, 2008 08:11 AM
FS: 30g iPod Video & 8g iPhone 1st Gen mpodgorski The Flea Market 3 August 7th, 2008 07:37 AM
New here. A gen question re: Rovers Emerson00 Misc. Chit-Chat 26 December 20th, 2006 10:53 AM
