GM Gen 4 conversion including LS - Page 84 - Defender Source
Old December 31st, 2016, 06:00 PM
stancey's Avatar
stancey
steven stancey
1988 Defender 110 LS, 1993 130 tdi
I still have it. My install looks similar. The guy I hired to help me do this used a mallet to put the ps pump pulley back on. I think it shoved the shaft inside the pump, hence the 1/4 difference.
Signed...
.annoyed
Old December 31st, 2016, 06:42 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Signed...
.annoyed
OMG! There is a special puller/pusher for GM power steering pump pulleys. You should be able to borrow one from your auto parts store. That pump is now junk!
Old December 31st, 2016, 06:47 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Signed...
.annoyed
seriously...you need to pull his man-card and have him buy you a new pump
Old January 1st, 2017, 10:13 AM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Also, what is everyone doing with the transmission crossmember. Leaving it off, or modifying it? Happy New Years.... I'm getting close...
I've put my TD5 X-member back and it looks fine... Lots of room below the trans and also for the exhaust shop to route the y pipe.
I'm for the russian pencil
I'm for the Russian pencil
Old January 1st, 2017, 12:23 PM
stancey's Avatar
stancey
steven stancey
This is what I'm looking at. I'm not even close. That is nicks y pipe you see...
Old January 1st, 2017, 12:24 PM
stancey's Avatar
stancey
steven stancey
Pic two
Old January 6th, 2017, 06:49 PM
Mostlymonki
Matt
1998 130, 1988 110
I was thinking of getting a d1/rrc v8 crossmember and seeing how that fits. Otherwise I'll make one.
Old January 15th, 2017, 09:12 PM
Psimpson7
Pete Simpson
2014 D90, 2001 D90, 1983 Stage 1 v8
Ok, I have a question again, this time regarding the emmissions stuff.
I have the 215-464 cannister from the spreadsheet and the vent valve (albeit the new superceeded one) Ac Delco 23481275
Am I correct in assuming the following.
The 3 ports on the top of the canister.
1 is for the corresponding plug on the valve which I have sat next to it in the picture - ***edit - believe it does go to the one on its own***
2. tank breather? ***edit just worked out I think the tank one is the larger one in the side with the pair of fittings - as it has a fuel pump logo next to it on the cannister***
3. Unsure? (the smaller one)
4. The rectangular one on the other line from the valve . I assume this has a corresponding connection that goes to the purge valve on the front of the engine?
Any clarification would be much appreciated. As this is being converted from a diesel I dont have any of this stuff to start from.
I may well have got this totally wrong!
thanks!
Old January 15th, 2017, 09:17 PM
phoenix37's Avatar
phoenix37
john
Sorry don't mean to hijack your post Pete but will your Defender be subject to smog check when its done?
Old January 15th, 2017, 09:20 PM
Psimpson7
Pete Simpson
No worries. It has to pass engineering which basically means I need to run the full emissions setup from the age of the car the engine was removed from. I probably wont need to actually get it tested for emissions levels but they will check to see that everything is there.
Old January 15th, 2017, 09:21 PM
phoenix37's Avatar
phoenix37
john
got it.. thanks.
Old January 15th, 2017, 09:25 PM
Psimpson7
Pete Simpson
No worries, think I have worked out 2 of the 4 connections now so updated my post if anyone happens to know!
Old January 16th, 2017, 12:39 AM
Psimpson7
Pete Simpson
And another issue now, the 2 connectors on my loom from Speartech do not fit the fuel tank pressure sensor or the vent valve from the spreadsheet.
the 2 pin connector appears to be the wrong way around (the retaining clip part), and the spacing on the 3 pins for the fuel tank pressure sensor is different to the connector.
Anyone know if the connectors to suit those are available from anywhere? I could maybe then swap them on the loom? assuming that would work...
I think the one for the fuel pressure sensor 13502903 may be AC Delco PT2425
and the one for the vent valve may be: ACDelco 19257603 GM Original Equipment Evaporative Emissions Canister Vent Valve Solenoid Jumper Wiring Harness
Can anyone confirm?
Thanks!
Old January 16th, 2017, 02:28 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Can anyone confirm?
Thanks!
EFIConnection.com
Vent Valve connector 100-00581
FTP connector 100-00726
Don't forget the terminals, seals, TPAs.
Old January 16th, 2017, 04:57 AM
Psimpson7
Pete Simpson
Thanks Nick, They appear to have pigtail versions aswell which may make my life even easier.
Do you have any comments regarding the emissions connections and which connection goes where from my post earlier with the picture?
Pete
Old January 29th, 2017, 02:47 PM
mattarm's Avatar
mattarm
Matt
1993 D110
I went with the 2 Lokar parts pictured in the attachments. Top is the sensor kit for the 4L80E and the lower is the vertical indicator similar to what is in the video. I have a couple of to-dos before completing the install but I wanted to confirm clearance on the indicator arm for the cable operated sensor. Pics are attached. Plenty of room so I don't anticipate any issues. Will post an update once totally functional
Originally Posted by Mostlymonki View Post
Has anyone tried this yet? Currently considering my options for reverse light, and I'll be using the vdo gauges so can't go the dd route.
ID:	199289   Click image for larger version
Old January 30th, 2017, 02:51 PM
mattarm's Avatar
mattarm
Matt
1993 D110
I am experiencing this same issue, and I know that no one used a mallet on my PS pump. My belt appears to be moving aft about 2 grooves at the crankshaft. Nick are you saying that I should need to shim the PS pump, and consequently the alt and idler pulley forward. I appears from photos that others are not. Presumably these washers would fit between the engine side bracket and the PS pump and alternator? Please advise.
Originally Posted by nmarkiw View Post
Did you harvest the idler hub from the factory idler pulley and use the three washers?
You must align the the power steering pulley with the crankshaft pulley.
Old January 31st, 2017, 06:26 PM
mattarm's Avatar
mattarm
Matt
1993 D110
I had to shim the entire assembly forward roughly 10mm to get the belt into alignment. Parts used:
  • 4 3/8 thick Bushings
  • 2 130mm M10 Bolts
  • 1 30mm M10 Bolt
  • 1 30mm M10 Button Head Bolt
Bolts were needed to replace bolts in kit to accommodate the additional width of the spacer. Pics attached. Test fire and belt seems to be where it needs to be. Actually probably about 1/8" over corrected but looks like it will work.
I am not sure why site keeps rotating my photos on upload.
ID:	201057   Click image for larger version
Old January 31st, 2017, 06:35 PM
stancey's Avatar
stancey
steven stancey
Follow up on the transmission crossmember. I spoke to a local shop that has done a bunch of LS swaps and they said that they use some 3/16" plate and some 2 x 4 square steel to make a new crossmember. They said that if you don't put something there to keep the frame from separating, then as soon as you pull over a curb with one front tire, it will put an immense amount of stress on keeping the frame together. Hope this helps someone.
Old February 2nd, 2017, 10:16 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
  • 2 130mm M10 Bolts
  • 1 30mm M10 Bolt
Wrong. No shimming is required. You installed it incorrectly!
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
