GM Gen 4 conversion including LS - Page 78 - Defender Source
Old October 1st, 2016, 12:04 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by Psimpson7 View Post
The l77 is a car engine with the low manifold. I am flipping mine to get the air intake to the back as I need to run an airbox and the routing of pipework from the front to the rear would be a pain
10:4, can you swap out to a truck intake to clear ?
Old October 2nd, 2016, 04:37 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Thanks for the comments guys.
Nick. You reckon it will be ok to cut off and tap and plug that boss even if it blocks the return feed that goes back along the top of the de-ac lifters? If so that will be the quickest option to get it running as I can do that, refit the standard plate with all the de-ac lifters still in there but just mapped off in the ecu. Them move the oil pressure sensor
Swapping them out along with the cam and so on I am happy to do down the track but would like to get it going first
Let me talk to Turnkey. That's the solution they provide.
------ Follow up post added October 2nd, 2016 01:42 PM ------
Yes, pay attention to the intake port configuration. (Cathedral ports or rectangle ports). 5.3l intake for the cathedral ports, 6.2l intake for rectangular ports.
Old October 4th, 2016, 10:52 AM
stancey's Avatar
stancey
steven stancey
1988 Defender 110 LS, 1993 130 tdi
I'm mounting nicks adapter to the transfer case and I don't have the original bolts. M8 by 30 mm grade 8 (which is what nick includes in the kit to mount adapter to tranny) seem to work on 4 of the 6 needed bolts, but 2 of them go internal in the transfer case and I can't tell if I need something longer. The parts book lists 3-4 different bolts for the mounting and I'm trying to source these locally. Thanks
Old October 4th, 2016, 11:01 AM
Just measure what you need. Make sure that the ones that go into the case do not extend past the housing as they will hit the gears, especially the upper one. Use thread sealant. Pretty sure they are all M10, not M8.
Stock bolt sizes are usually in the manual. If not, the size can be decoded from the part number.
Old October 5th, 2016, 08:02 PM
stancey's Avatar
stancey
steven stancey
Got them, thanks...
Old October 9th, 2016, 04:18 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Nick, what wiring configuration did you use for the MSD tach module to VDO tach input ?
Old October 16th, 2016, 07:31 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Use the voltage trigger scheme. White to the ECM, violet to the tach.
Configure the ECM for 15 pulses high, 15 pulses low. Attach a 680 ohm pull-up resistor between white and red.
Old October 21st, 2016, 12:45 PM
The Dro
Dro
1988 Ninety
Is there an official For Sale thread for the LS conversion kit?
Old October 21st, 2016, 01:06 PM
spyder625
110
Part List
it would be great if we can get an entire parts list as well for easy referencing... thanks mike
Old October 22nd, 2016, 08:25 AM
Step away from the keyboard Pedro!
Originally Posted by pendy
I'm here for the D's
Old October 23rd, 2016, 04:10 PM
Mtanzania
Frank
1994 D1 300tdi - Sold :-(
Nick,
Has there been any further development of a kit for a D2?
94 D1 300tdi - Sold
93 LWB-Isuzu diesel 5 speed
Old October 24th, 2016, 05:19 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Originally Posted by Mtanzania View Post
Nick,
No. life is getting in the way.
Old October 24th, 2016, 05:49 PM
The Dro
Dro
1988 Ninety
LOL
Old October 24th, 2016, 06:32 PM
Mtanzania
Frank
Totally understand!
Thanks for getting back with me.
94 D1 300tdi - Sold
Old October 30th, 2016, 09:02 AM
Buddy Lee
Tobias
TBD
I was wondering the same thing. I've had really bad luck with Rover donor engines the last year or so. If this last one turns out to be a dud too. I'm going to scrap Rover engines and start working on a swap like this.
It would be nice to have a summary page that list what is currently available, pricing and what else is needed (other than the engine/trans obviously). I have the attention span of a nat and reading through 1,500 post just won't happen.
Old October 30th, 2016, 09:46 AM
phoenix37's Avatar
phoenix37
john
you need to PM Nick..
Old October 30th, 2016, 10:47 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Thank you nick for all your help! Finally getting to deliver the truck to its new owner today... Cross your fingers!!! With nicks help we where able to ad paddle shifters and cruise control, the Dakota digital is well worth the $$$, allowing you to view all the major vitals and is super easy to install(if you know what your doing) thanks again the truck came out great.
Old October 30th, 2016, 08:16 PM
skitzy's Avatar
skitzy
Nick
91 D90 2.5NA doing LS Gen IV Thing
Nice looking truck
Congratulations
Old October 30th, 2016, 09:18 PM
defender1844
Amit Likhyani
can you post pictures of the cruise and paddle shifter setup?
I have the Dakota gauges wired with canbus and a momo wheel. 2 questions:
1) how are you wiring the sensors to the dakota? Canbus or direct?
2) how are you wiring the cruise and paddle shifters? The reason I ask is that i tried to connect a PLX devices bluetooth module via a y-adapter so I had 2 OBD connectors going into my ECU. Unfortunately that didn't work. Just wondering if the body control module is a pass through so you can use the can bus input to the dakota?
------ Follow up post added October 30th, 2016 08:18 PM ------
3) what kind of steering wheel and hub are you using?
Old October 30th, 2016, 09:32 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I'll get all the info and post it
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
