GM Gen 4 conversion including LS - Page 77 - Defender Source
Old September 27th, 2016, 11:56 AM
GRNWOLF's Avatar
GRNWOLF
1985 Defender ex MOD OM617
Originally Posted by Cpancho View Post
Hi everybody!, I hope you are all doing great.
I just come home from a 4 month road trip with my 1966 series 2a with a LS pulling an 1960 aistream 19ft all around USA and canada (about 13,000 miles and everything working like new, so happy with the swap)...
I just got a land rover 101 FC and I thinking on putting a ls3 to 6l80 and lt230 but I was wondering how long it is everything from the pump to the joke and if will fit in a 101 wheel base. someone can measure it for me?
thanks in advance and have a great weekend.
francisco
sorry for the typos and gramar
That is so cool. What gearing do you have?
Sent from my SM-G930V using Tapatalk
GRNWOLF
1985 Defender 110 ex MOD Wolf Tithonus; OM617
Phoenix, AZ
Old September 27th, 2016, 11:58 AM
Cpancho
Francisco
1974 land rover series 3 109
I have a 4l60e with a forbyn bross tranfer case and 3.54 dif
Old September 28th, 2016, 01:18 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
thank you guys!, if someone can tell me the total lengh of the LS engine from the pump to the back joke with a 6l80 and the adapter to a lp230? is for a 101 proyect.
Which LS? LS3 or truck LS (LC9,LMG,L94)
Old September 28th, 2016, 08:48 AM
Cpancho
Francisco
truck ls, I don't have it yet, maybe a gen V. My series have a lm7.
Old September 28th, 2016, 09:39 AM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
My L94 is 140cm from water pump pulley tip to trans tail housing
I'm for the Russian pencil
Old September 28th, 2016, 10:25 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
GenV won't fit. High pressure fuel pump will hit the steering box and the engine mounts have been relocated.
Old September 28th, 2016, 11:31 AM
Cpancho
Francisco
thanks markiw, it is great to know that before buy the engine. I was thinking l94 6.2 because of the size of the Forward control?, i know 5.3 have a lot of power too. I'm planning to build a camper on it.
can you pm values of the adapter + engine mounts?
do you have engine+6l80+adaptor+230 value package?
Francisco,
------ Follow up post added September 28th, 2016 08:35 AM ------
you mean 140cm to tail of the tranfer case (yoke) or transmission?
Old September 28th, 2016, 02:40 PM
Omero's Avatar
Omero
Omar Alomar
140cm to the transmission... Adapter= 6cm... LT230 = 29.5cm
140+6+29.5 =175.5cm (approx) from wp pulley nosetip to prop shaft mating face.
Sent from my SM-G920F using Tapatalk
Old September 30th, 2016, 01:45 AM
Psimpson7
Pete Simpson
2014 D90, 2001 D90, 1983 Stage 1 v8
I have a question related to DOD.
My engine is an L77.
I was prepared for an issue when turning around the inlet manifold with the oil pressure switch being on a riser on the closing plate.
However its possibly slightly more involved because of the DOD.
The oil that comes up to the pressure switch is then fed back down and along the top of the 4 de-ac lifters.
This is the cover plate with the oil pressure riser that gets in the way of the throttle body. next to it is the plug for the DOD De-ac lifters. You can see the raised section that goes along the middle in the casting which is the path the oil takes on its return from the pressure switch
So this is with the inlet and cover plate off.
And this is the underside of the cover plate:
Here is the return from the pressure switch:
Now looking at the same plate on the LS2 pics I can find it appears that the oil pressure riser just goes to the switch and is blind. Is that correct? Also the oil feeds that went to the lifters are blocked.
This image from a guy on another forum shows the path of the oil.
And this one shows the difference in where the oil goes when the de-ac lifter is deactivaed and activated. To me it looks like when the de-ac lifters are activated electroncially they allow the oil to bypass the lifter itself meaning the valves don't open. Am I correct here or miles off the mark?
So in short I guess my questions bearing in mind that the loom made for me by Speartech wont have the DOD enabled are:
1. Can I fit an LS2 closing plate and just block off the oil feed that was to the pressure switch. without causing any issues, or is the oil required at the top of the de-ac lifters even if they are disabled?
2. This plate would also block off all the feeds that come up in the 8 upstands. I know they are blocked on the cars without any DOD stuff. Would this cause any issues with the DOD lifters being left in place
If this will cause issues I may have to remove the entire DOD stuff, which I probably will do down the track but i was hoping to just get it running and see how it went first.
thanks for reading!
Old September 30th, 2016, 09:48 AM
Landy_Andy's Avatar
Landy_Andy
Andy
I think you need to do the complete DOD delete, Texas Speed and others do kits with all the parts you need.... Cam, lifters etc.
Old September 30th, 2016, 10:22 AM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
I had a brand new DOD engine malfunction and bend two pushrods shortly after startup, and ended up deleting the system. All you'll need are new lifters and a different valley pan cover without the solenoids.
I wouldn't risk running the DOD lifters with the oil galleys blocked off.
-Ash
Geared Restoration Co.
352-572-3236
Old September 30th, 2016, 12:06 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Hmmm first I have heard of this need to figure out what to do since Rob was just about ready to fire mine up in the next week or two.
2011 LC9 I only flipped the manifold per the directions nothing else.
Old September 30th, 2016, 03:26 PM
Landy_Andy's Avatar
Landy_Andy
Andy
So how did you clear the oil pressure sender & sensor, looks to be a stack of work from this thread : Intake manifold reversal on AFM/DOD engine - LS1TECH
Old September 30th, 2016, 04:12 PM
Ash's Avatar
Ash
Ash Heller
Truck manifold fits fine, it's the car manifold that you'll have clearance issues with.
-Ash
352-572-3236
Old September 30th, 2016, 04:41 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I have a truck motor 2011 LC9 out of a 4x Silverado. Truck manifold clears I was more concerned about the oil and DOD issues mentioned. Not sure if they apply or not Here is a picture of the truck manifold after being reversed. Pic from my truck courtesy of Rob
Old September 30th, 2016, 04:48 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
You can saw off the eop boss, pipe tap and plug. Then move the eop down to the oil cooler bypass.
Old September 30th, 2016, 05:07 PM
Psimpson7
Pete Simpson
Thanks for the comments guys.
Nick. You reckon it will be ok to cut off and tap and plug that boss even if it blocks the return feed that goes back along the top of the de-ac lifters? If so that will be the quickest option to get it running as I can do that, refit the standard plate with all the de-ac lifters still in there but just mapped off in the ecu. Them move the oil pressure sensor
Swapping them out along with the cam and so on I am happy to do down the track but would like to get it going first
Old September 30th, 2016, 09:00 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Correct me if I'm wrong (Mark) but the L77 is a car engine with the lower inlet manifold, thought it was just the truck ones that needed flipping to clear the bonnet ?
Old September 30th, 2016, 09:12 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Snagged this pic of one of my FB pages I follow, guys going to post the file for the lift frame... nice
Name:	LS Engine lift frame.jpg
Old September 30th, 2016, 10:37 PM
Psimpson7
Pete Simpson
The l77 is a car engine with the low manifold. I am flipping mine to get the air intake to the back as I need to run an airbox and the routing of pipework from the front to the rear would be a pain
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
