GM Gen 4 conversion including LS - Page 73 - Defender Source
Old August 11th, 2016, 12:53 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
Don't forget to mount your emergency brake drum on the back of your LT230, it will take up that 2 inch gap in the rear driveshaft.
Originally Posted by Jaded-7 View Post
Here are a few pics. Used correct mount brackets as per bom. Did have to cut right side (us Defender/d1) to fit however.
sorry for the orientation
1. upside down pic of left side (drivers US, i.e. Right side of pic is towards rear of car.)
2. upside down pic of right side (passenger US IE left side of pic is towards rear of car)
3. Front shaft all the way pushed in, no way it will clear bolts. (it did come out this way though...)
4. Rear shaft. I just pulled the shaft out, didn't really tug on it, but it looks a long way off... unless it will extend farther.
Old August 11th, 2016, 07:26 PM
nealcain
Neal Cain
1988 D110
How do you screw in the VDO 323095 sensor?
I found this drill bit thing in my parts package from Nick, what is it for?
Old August 11th, 2016, 09:11 PM
mattarm's Avatar
mattarm
Matt
1993 D110
how are you guys wiring up the reverse lights? I was hoping to be able to use the neutral safety switch as my reverse switch, but not sure how.
I was planning to use the lokar cable operated shift indicator kit, similar to what is shown . Based on a conversation with the guy at Lokar it will perform both functions and can be remotely mounted to handle the clearance issue.
Old August 11th, 2016, 09:44 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
The face of the drum is only 0.25" thick, so it won't offset any notable gap.
There's a plug towards the rear of the right hand cylinder head, along the same face that the exhaust manifold bolts to. That's your hole for the sender. I can't remember exactly since the last LS swap I completed pulled engine temp off CAN bus, but I remember having to modify an adapter to fit that sender in the head. Let me dig around and see if I can find record of that process.
The drill bit is for drilling holes for the engine mounts. The bolt holes closest to the steering box are tricky to drill if the box is still in place, so Nick made that little guy as a solution. Just run it off an air ratchet and it should fit just fine.
-Ash
Geared Restoration Co.
352-572-3236
Old August 14th, 2016, 08:30 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Maybe I missed it (I have read the entire thread, but it's been a while).
What fuel pump is recommended for the LC9 engine?
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old August 14th, 2016, 08:41 PM
nealcain
Neal Cain
1988 D110
Thanks for the good info Ash.
I just measured my shaft length from center to center of u-joints-
front 20 3/4, rear 40 1/2 I am hoping they are useable. Can someone verify?
Mahalo
Old August 14th, 2016, 08:55 PM
nealcain
Neal Cain
1988 D110
Paul.
Walbro F20000141
Old August 15th, 2016, 07:38 PM
Jaded-7
Harrison
Thanks ^
Another question, Anyone having trouble with the alternator charging?
I've got mine plugged in and hooked up to the PCM, but it doesn't seem to be charging. Just have the 2 wires. Brown to X2-61 and gray to X2-32. (and obviously the big one to the battery)
I did my own wiring, but never came across a wire that seemed to need an input from another source. engine is a 2011 LC9.
Thanks.
Old August 15th, 2016, 09:02 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
I'm running this with a controller on my Lq4 powered buggy...
Old August 16th, 2016, 12:06 AM
Ash's Avatar
Ash
Ash Heller
Paul.
Paul since you're running an ROW truck you're going to need a different fuel pump setup; Nick calls out an in-tank pump for the NAS configuration.
Any 255LPH inline pump will work, just stick with a quality brand like Aeromotive, Mallory or Walbro. You'll also want a pre-pump inline filter in the 80-100 micron range (although I've seen some manufacturers call for 40) to keep the pump healthy.
A little piece of advice -- try mounting everything, including the fuel pressure regulator, as close to the tank as possible so that your return line is as short as can be. You'll eat up a lot of fuel hose otherwise and the stuff ain't cheap.
-Ash
352-572-3236
Old August 16th, 2016, 09:43 AM
Jaded-7
Harrison
slight update. the gray Field generator wire, is outputting 5volts when motor is running, the brown wire has no voltage when disconnected.
I did disconnect the plug as well, to try and "trick" the alt to going into default mode (13.8v) but no luck. I didn't rev up the motor at all, so not sure if its got a turn on speed.
Engine only had ~20,000 miles on it, so i don't think the alt would be bad. any suggestions?
Old August 16th, 2016, 09:59 AM
phoenix37's Avatar
phoenix37
john
bring it into a local auto parts store and have them test it.
Old August 16th, 2016, 12:35 PM
Jaded-7
Harrison
and apparently its dead... they've got the bigger 160 amp in stock... but somehow I know that if i get that one, it will hit my hood... d'oh! guess we'l see...
Old August 16th, 2016, 12:51 PM
86Defend110
Jesse
If you have the stock accessory brackets the larger alternator will hit the hood.
ID:	155730   Click image for larger version
Old August 16th, 2016, 12:53 PM
phoenix37's Avatar
phoenix37
john
i relocated mine to the passenger side.
Old August 16th, 2016, 02:12 PM
Ash's Avatar
Ash
Ash Heller
Nicks accessory brackets are cheap and will put the alternator at a safe location.
-Ash
352-572-3236
Old August 25th, 2016, 10:34 PM
fesik
Jonathan Corcoran
1987 Land Rover 90 County 2.5NA Die
It may have been addressed already but I haven't seen it, is there a GM 6 speed automatic tranny option that ill fit as well as the 4 speed? Thanks!
Old August 25th, 2016, 10:38 PM
phoenix37's Avatar
phoenix37
john
Nicks adapter is for the 6l80....6 speed.
Old August 30th, 2016, 07:25 PM
Philip
Philip
Various
Just ploughed through 74 pages - is the adapter compatible with the RRC Borg Warner transfer box (I know the front prop length is different from the LT230)?
Old August 31st, 2016, 01:42 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Yes, the adapter will bolt up to the Classic BW.
No, the chain in that transfer case won't hold up to the HP. Best to just swap that BW out with an LT230.
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
» Defender Registry
D
drsmiley
Lola
Nooner
Add your Defender
