GM Gen 4 conversion including LS - Page 72 - Defender Source
Old July 25th, 2016, 07:47 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by o2batsea View Post
You can also make up rad hoses from those silicone elbows. That's what I did.
Yup... but I wanted ones that were off the shelf in the local parts store, one of my reasons for swapping out the old 3.9 was to make servicing a little easier/cheaper as we only have NAPA & Lordco here. Anything LR specific has to be shipped in on my dime and that's generally 30bux minimum every time. If your living in a large metro area it's not a real issue.
Old July 25th, 2016, 07:53 PM
But if you get silicone, it never needs to be replaced, so access to replacement parts is not an issue.
Old July 25th, 2016, 11:40 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I hate it when Red makes sense.
Old July 26th, 2016, 12:56 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Bit late now, cause I cut'em up....
Old August 4th, 2016, 07:53 PM
Psimpson7
Pete Simpson
2014 D90, 2001 D90, 1983 Stage 1 v8
Stupid question probably! (And I have searched the thread as best I can)
I have one of Nicks adaptors and am about to buy a 2015 L77/6L80E out of a Holden Commodore SS
I have been buying up other parts off the list including the truck sump/oil pickup, and also the Lokar Shifter.
My question relates to the Lokar Shifter. Can this shifter be used with the tapup/down (tiptronic) functions that the factory in this case Holden shifter can?
Or will I need to stick with the std shifter?
cheers!
Old August 4th, 2016, 08:01 PM
phoenix37's Avatar
phoenix37
john
Is a 2015 still a Gen IV or is it Gen V? and yes you can use the tap up/down function with nicks conversion
Old August 4th, 2016, 08:09 PM
Psimpson7
Pete Simpson
Gen 1V I believe. I think this is the very last of them?
Tables and comments on the links below suggests that the l77 is still a Gen4
Holden L76 and L77 'Generation IV' V8 engines
https://en.wikipedia.org/wiki/Holden_Commodore_(VF)
I'm going to see it shortly. Are there any obvious things to check to make sure?
Edit, just done some googling. Its definitely not a gen V.
Old August 4th, 2016, 08:21 PM
UL1700
James
Defender 50th
Make sure you get the parts to convert the 2wd box to a 4! Is a bodge but it still seems to be working after 5000 kilometres 😉
Old August 4th, 2016, 08:23 PM
Psimpson7
Pete Simpson
Got them! Nick got and supplied me with the parts you mentioned in your thread!
Old August 5th, 2016, 02:11 AM
Psimpson7
Pete Simpson
Big step forward in progress on my conversion. Just put a deposit on an engine and box. Should pick it up next Tuesday
It's an L77/6L80 from a 2015 VF Holden Commodore SS. 37000km with everything, inc Auto and shifter, looms, ecu, bcm, throttle, airbox, cats etc etc
Out of this:
Old August 6th, 2016, 09:17 AM
mud ruts's Avatar
mud ruts
Chris Ray
97 Disco
Are there any pictures with the front drive shaft installed in the truck.
It's looks scary close.
Mud Ruts Off-Road Rover Repair shop 614.301.1574
Old August 7th, 2016, 07:56 AM
Mostlymonki
Matt
1998 130, 1988 110
I'm taking my steering box off to recondition before putting everything in, and my old steering pipes are shot... will I be reusing the defender pipes and just bolting on the adapters in nick's bom? Though I'd check before ordering new pipes.
Old August 7th, 2016, 01:47 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Some where near the start of this thread are pics of the underside.
Old August 11th, 2016, 11:05 AM
Jaded-7
Harrison
how are you guys wiring up the reverse lights? I was hoping to be able to use the neutral safety switch as my reverse switch, but not sure how.
Old August 11th, 2016, 11:32 AM
defender1844
Amit Likhyani
I'm waiting on the body control module but if someone figures out something else that works with the Lokar shifter, I'm all ears.
Old August 11th, 2016, 11:35 AM
defender1844
Amit Likhyani
this is an L94 but should show the front drive shaft
Clears no problem
Old August 11th, 2016, 11:53 AM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
The BOM calls for braided steel hoses in place of pipes. The adapters convert from the land rover 14/16mm inverted flare fittings to -6an to be used with braided steel hoses. You won't need your land rover PS pipes or reservoir.
Old August 11th, 2016, 12:01 PM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
My plan is to fab a bracket and position one of these near the shifter mechanism so it's activated when in R.
Sent from my SM-G920F using Tapatalk
I'm for the Russian pencil
Old August 11th, 2016, 12:02 PM
defender1844
Amit Likhyani
Please keep me in the loop.
Old August 11th, 2016, 12:12 PM
Omero's Avatar
Omero
Omar Alomar
Absolutely!
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
