GM Gen 4 conversion including LS - Page 68 - Defender Source
Old June 23rd, 2016, 10:37 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Originally Posted by Paul K View Post
Did I read somewhere that the stock (LC9) A/C compressor won't work?
It works with left hand drive only. Can't remember if yours is left or right.
Old June 23rd, 2016, 11:57 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
My Ninety is RHD. I think that means I need a different compressor. Can anyone confirm? If so, what make/model do I need?
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old June 24th, 2016, 09:41 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Mark will correct if wrong but you'll need to use a Sandon mounted with his brackets to clear the steering box. There is a pic in the early, early part of this thread.
Old June 27th, 2016, 10:00 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
What's the best option for a radiator with the LC9 engine? Nick's? Or the Allisport? Mine is in need of replacement so I want to make sure I get the best one for the job.
Paul.
Old June 27th, 2016, 10:57 PM
Landy_Andy's Avatar
Landy_Andy
Andy
All:
Paul.
I suggest you go with Nicks, you'll not get the Alisport rad in with the fan shroud, I moved my engine back 1" to allow for it.
Old June 28th, 2016, 08:24 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks Andy- will do.
Old June 28th, 2016, 01:58 PM
Landy_Andy's Avatar
Landy_Andy
Andy
No worries, just so everyone reading is clear I already had the Allisport rad for the 3.9 that was in my truck and as I needed to move the t'case mounts back to accomodate the crawler box, moving the engine mounts back 1" wasn't a big deal. Have posted a couple of pics of the rad hoses I used in the Gen III thread for info.
Old June 29th, 2016, 09:39 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
69 pages. Does anybody know if there is a website for rover works or how to get in contact with Nick's shop? This thread is impossible to follow.
You little rebel, I like you.
Old June 29th, 2016, 10:05 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Send Nick a PM. Worked for me!
Old June 30th, 2016, 12:34 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
He got back to me. Thanks.
Old July 4th, 2016, 09:14 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
hood strut
What do you think about this hood strut configuration?
Old July 4th, 2016, 09:51 PM
defender1844
Amit Likhyani
Nick, I'll take it no questions asked. Talk next week after I've got the truck home. Need to do the deal on the diagnostic tool anyway.
Old July 5th, 2016, 01:51 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Neat... And you also need to make a wide brake pedal converter plate as well as a robust 'dead' pedal... Not that your slacking.....
Old July 5th, 2016, 03:13 AM
defender1844
Amit Likhyani
Andy, Ashcroft seems to have the wider brake pedal and dead pedal covered. I placed the order and will have them this week. Nick needs to focus on the strut kit, body control module and paddle shifters for momo wheels to go with tap up/down.
Old July 6th, 2016, 04:54 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Originally Posted by Ash View Post
The one I installed went in the very upper right corner of the vertical footwell panel. I thought the pedal was in just the right spot. I dug through my phone but can't find any photos unfortunately, but for reference here's one of the old style pedal on Nick's adapter.
-Ash
Ok, here is the scoop on the Lokar pedals. The one pictured is the old style, DBW-GM01. Which is compatible with my pedal adapter.
The current one (all billet) is BDBW-GM01.
The older ones are still in limited stock at various distributors. At least you can determine which one you are getting based on the part number.
Nick
Old July 6th, 2016, 05:04 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
This forum needs a re-org. LS swap should have it's own sub section instead of a single thread.
Old July 6th, 2016, 07:56 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I agree, move all the LS build threads & tech into one place... Mods.... ?
Old July 6th, 2016, 07:58 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Hood strut looks simple and straight forward. Will that work in conjunction with the NAS air cleaner bracket?
Also, after having done a couple of these swaps with Nick's components I'm pretty familiar with the process. I know he's a tough guy to get a hold of at times, so if anyone needs technical advice or a sounding board I'm happy to assist where possible.
-Ash
Geared Restoration Co.
352-572-3236
Old July 6th, 2016, 08:07 PM
AdamSanta85
91' D90 200TDI
I also think it needs a Interior/Exterior, Lighting/Electrical, Wheels/Tires, Engine, Brakes/Steering/Suspension, Transmission, Service/Maintenance, Custom Fabrication, Parts reviews sections broken out
Old July 6th, 2016, 08:11 PM
Ash's Avatar
Ash
Ash Heller
Couldn't agree more.
-Ash
352-572-3236
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
