GM Gen 4 conversion including LS - Page 66 - Defender Source
Old May 31st, 2016, 08:27 PM
phoenix37's Avatar
phoenix37
john
Originally Posted by don View Post
Wait...are you doing an LS now???
He must of gotten to drive one...
Old May 31st, 2016, 08:44 PM
The Classic blew the engine. The 2a is getting the 300 that is being built now.
Old May 31st, 2016, 09:49 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I keep telling my bro-in-law to "just LS" his RRC every time he has an issue with it. I am sure LS Defenders are great to drive but I would wager an LWB LS would be even better. Please keep us in the loop on that (actually the 2A as well) project!
Old June 1st, 2016, 01:35 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Just a heads up:
https://www.ebay.com/itm/191884765669
Cheap for now, but hey, in for a penny, in for a pound......... Ahhh, screw it. If you're going LS, Go BIG or go home, right?
Now LSA big is like John Holmes getting enlargement surgery, but who wouldn't do it if they could :-) Jwillia is going to travel back in time when he gets that monster built! Can't wait ;-)
"Barry is correct!"
Old June 1st, 2016, 09:08 AM
That one has def got my attention, but there are other possibilities that are closer to me with fewer miles.
Old June 1st, 2016, 09:59 AM
Jaded-7
Harrison
Anyone know what connector the blue connector is? It's next to fuse block x2 on wiring harness but I can't seem to find it on gmupfitter.
Also, did the Gen Iv with 6l80 use a TAC box, or do I connect my pedal directly to the harness?
Thanks.
Old June 1st, 2016, 10:05 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Cab/bulkhead connector. Pedal gets wired in directly to it. No Box for the pedal. Send me an email and I will forward you a schematic.
Old June 1st, 2016, 05:31 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I bought an LC9 & 6L80e from a wrecked 2010 Silverado 1500 with 41.5k on the odometer. Paid $3k. Comes with exhaust manifolds, air cleaner, wiring loom & 'brain'. Think I did pretty good?
I'm committed now!
Current fleet: '85 Ninety 3.9 V8i Auto SW,'07 BMW 335Xi.
Old June 1st, 2016, 05:43 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Same setup I have
Old June 6th, 2016, 01:13 PM
Jaded-7
Harrison
ok, another stupid question, but how does the Lokar Pedal assembly (DBW-GM01) attach to the Pedal adapter? Not sure if i'm missing something, but i'm not getting it... i've got one long forward facing bolt on the adapter, and no obvious mounting holes to actually attach the assembly. Do I need to drill my own holes?
Old June 6th, 2016, 01:28 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
There are two versions of the pedal that I've encountered. Nick's adapter bracket is configured for the earlier style that has a cast aluminum body and two diagonal through holes for bolts/studs. The new version is machined billet aluminum and has two 3/8" (if I remember correctly) captured nuts in the body.
-Ash
Geared Restoration Co.
352-572-3236
Old June 6th, 2016, 01:31 PM
Jaded-7
Harrison
that would explain it... I must have the new version. should i send back my pedal to summit? anyone know where i can get the older version?
Old June 6th, 2016, 01:36 PM
Ash's Avatar
Ash
Ash Heller
The new one works fine, it's just a function of how easy you want the install to be. Summit sent me a new style, but the one provided with the 6.2 from Turnkey was the older version.
When I ran the new version I just made a simple template off the back of it to locate and mark the two holes that needed to be drilled, then just bolted it in place from the outside. It's a two-man job but really straight forward and the splined pedal can be clocked to the appropriate position without issue.
-Ash
352-572-3236
Old June 6th, 2016, 01:53 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
-Ash
That sucks. Were you able to fit the new version?
Old June 6th, 2016, 01:57 PM
Jaded-7
Harrison
just called and talked to the Lokar guy. Apparently the new version has better throttle response etc. Summit didn't have any old versions and Lokar have already stopped making them. Drilling 2 new holes won't be hard... but I just wish i didn't have to! lol... oh well!
Old June 6th, 2016, 05:49 PM
UL1700
James
Defender 50th
New version works and almost lined up with my existing peddle holes, just use the top hole and elongate the bottom (less then half a bolt hole) is a bitch to fit on your own though took me nearly an hour my only complaint with it is I don't think you can fit it as high up the footwell as would possibly be perfect?
Old June 6th, 2016, 06:26 PM
Ash's Avatar
Ash
Ash Heller
The one I installed went in the very upper right corner of the vertical footwell panel. I thought the pedal was in just the right spot. I dug through my phone but can't find any photos unfortunately, but for reference here's one of the old style pedal on Nick's adapter.
-Ash
352-572-3236
Old June 6th, 2016, 08:34 PM
UL1700
James
Defender 50th
20151226_173309 by James Elphick, on Flickr
20160111_165647 by James Elphick, on Flickr
Old June 9th, 2016, 10:18 AM
Jaded-7
Harrison
Yea, I still went ahead and used Nicks adapter plate, but just marked and drilled through both the plate and footwell for extra support. It works nicely.
Any updates on the adapters?
Old June 10th, 2016, 11:21 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
They shipped Wednesday and are in route to me. I should have them early next week.
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
