GM Gen 4 conversion including LS - Page 64 - Defender Source
Old October 8th, 2007, 11:17 AM
JBOD77
Jonathan
1995 D90 ST Beluga Black
This is where I'm supposed to write something witty and funny; or something.
Old May 21st, 2016, 09:46 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
https://www.gmpartsonline.net/ls-lsx-crate-motors.html
-Is there a difference between the 6L80 & 6L80E?
-Looks like the best option is the LH6 or LC9?
-Any year's fit better than others?
Current fleet: '85 Ninety 3.9 V8i Auto SW, two '95 Discoverys (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old May 21st, 2016, 10:19 AM
phoenix37's Avatar
phoenix37
john
I have an LH6 in mine... All aluminum engine.. i was told to try and get engine and trans from the same year.. i don't think there is a difference from the 6l80 and 6l80e but can't confirm.
Old May 21st, 2016, 11:05 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks! Did you consider the LC9?
Old May 21st, 2016, 01:16 PM
Landy_Andy's Avatar
Landy_Andy
Andy
The 'e' designates the transmission is electronic control rather than the old manual cable. The 6L80's are all electronic, people just tend to drop the 'e' off when they quote them, unless some one knows otherwise.
Old May 22nd, 2016, 04:59 AM
UL1700
James
Defender 50th
Originally Posted by SGS714 View Post
Can't help but mention I owned a RPI Stage III 4.6 and it was lackluster at best. Rebuilt top end 2x and set it out back to rust after 45k miles. Don't mean to sidetrack discussion but I still have hard feeling 4yrs and $10k later.
You did better than me, mine cooked at 25000 ish
Old May 22nd, 2016, 09:42 AM
defender1844
Amit Likhyani
I had a hot rodded 4.6 controlled by a Megasquirt. It was never going to deliver what I wanted. Total waste.
Old May 22nd, 2016, 09:50 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
Ok, so I read the entire thread but still have questions;
-Is there any preference for the LC9 over the LH6?
-Has anyone used an Allisport radiator with an LC9 & 6L80e?
-I saw that the 5.3 motor 'drops right in' but also see Nick is selling mounts. ?
-Any ballpark estimates on labor & parts, sans motor & trans?
Paul.
Old May 22nd, 2016, 09:59 AM
phoenix37's Avatar
phoenix37
john
Paul from what i understand the LH6 and LC9 are essentially the same motor but one was flex fuel and the other wasn't. I might be wrong. What motor do you have now? You will need motor mounts. If you have a V8 you would use Nicks bolt in mounts and i think if you have a diesel you have to weld in mounts. Did you get the BOM (list of materials and parts) from Nick? If not send him a PM.
Old May 22nd, 2016, 10:18 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I'm not really interested in a flex fuel engine, but want aluminium for weight saving & corrosion resistance. I am currently running a 3.9 out of a '96 D1, but will do the GM upgrade when I replace my chassis & bulkhead. I PM'd nick but no response as yet.
Thanks!
Old May 22nd, 2016, 12:44 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Originally Posted by Paul K View Post
I'm not really interested in a flex fuel engine, but want aluminium for weight saving & corrosion resistance. I am currently running a 3.9 out of a '96 D1, but will do the GM upgrade when I replace my chassis & bulkhead. I PM'd nick but no response as yet. Thanks!
If you like, I can send you my old bom from Nick. Just so you have a general cost estimate.
Old May 22nd, 2016, 01:54 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I have a V8 Allisport rad (with fan shroud) with my LM7, I moved the engine back 1" to accommodate the fan shroud, without that I'm 90% certain the passenger side fan would contact the nose of the water pump. Pic's in the Gen III thread.
Old May 23rd, 2016, 02:22 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Nick:
I need an adapter. Do you have any available? I sent you a PM.
Paul.
Originally Posted by nmarkiw View Post
Hydro-boost is coming for the Defender! Stay tuned.
Old May 23rd, 2016, 02:37 PM
phoenix37's Avatar
phoenix37
john
Nick:
Paul.
He posted this on May 11th..
"The 25 housings were just shipping from the foundry. They have to be machined, then shipped to me. Looks like two more weeks".
Old May 26th, 2016, 11:19 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
adapters
I was out last week for surgery. Trying to get caught up on emails and PMs.
I received email this morning that the adapter housings were delivered to the machine shop from the foundry, then sent back out for heat treat, and are now on the lathe. (Two lathe operations, three mill operations.) They should be ready to ship to me June 3 along with shafts.
Nick
Old May 26th, 2016, 11:46 AM
ersatzknarf's Avatar
ersatzknarf
Frank
'96 hybrid
Hope all is well, Nick !
__________________________________________________
shoefnik wrote: "Itís funny how that moral line you draw for modifying your Rover changes as your needs change."
Old May 26th, 2016, 12:04 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Just a HUGE kidney stone. (7mm x 6mm)
Old May 26th, 2016, 02:37 PM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Nick
Sorry to hear that... Hope you're all well.
I'm for the Russian pencil
Old May 26th, 2016, 08:37 PM
dickyjoe
Richard Lane
1958 Series 2 SWB
Ouch! Hoping your on the mend!
Old May 26th, 2016, 08:41 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Nick
Put me down for one & get well soon Nick!
Old May 26th, 2016, 08:49 PM
phoenix37's Avatar
phoenix37
john
damn! Feel better man.
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 05:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 11:58 AM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 08:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 04:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 08:33 PM
