GM Gen 4 conversion including LS - Page 63 - Defender Source
Old May 19th, 2016, 11:35 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Originally Posted by Jaded-7 View Post
Does anyone know the Diameter of the stock maf tube for a 5.3? Wondering if we have to use the adapter and an older style MAF or if we can use something like this and the stock sensor.
http://www.amazon.com/dp/B0035GZSP8/...F4JMRJ1X39CB36
Of course spectre only makes a 3 and 4 inch version, where the old style had a 3.5 inch inlet i believe...
I'm using 4" tube with no issue on my LQ4…The Spectre stuff comes with a reducer ring, FYI
Old May 19th, 2016, 12:39 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Each different style MAF requires a different calibration table. They are not directly interchangeable. LS2, LS1, LS3, and truck. Changing a the tube size for a cartridge MAF requires a new table. It will run lean, and may throw codes if out of range. I install the LS2 MAF table my customers for this conversion.
Old May 19th, 2016, 01:34 PM
Jaded-7
Harrison
anyone know the tube size for the truck? 2011 sierra 1500. lol!
Old May 19th, 2016, 02:31 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
This made me curious…so I looked up a K&N kit (which I wouldn't buy) and they supply a 4" ID to 3.5" ID reducer for thier kit.
http://static.summitracing.com/globa...-3070_Inst.pdf
Does that help
Old May 19th, 2016, 07:13 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
Seriously considering a GM engine for my '85 Ninety...
-Is there a code name for the GM gen IV engine? Are there different versions? What year(s) was it used, and in what?
-What's the best automatic transmission to use?
-Will I have to upgrade my diffs/axles?
-Does anyone make a big brake kit so I can still stop?
-Will the exhaust system need to be built from scratch?
Thanks!
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old May 19th, 2016, 07:17 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Originally Posted by Paul K View Post
All:
Thanks!
Paul.
Paul, you've got some reading to do. All of these questions will be answered in this thread.
Old May 19th, 2016, 07:23 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I was hoping someone knew the info off hand, to save me reading through all 750,000 posts!
Old May 19th, 2016, 07:39 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
The problem is that the thread will only get longer if the same questions get asked over and over. Most of these questions will be answered in the first few pages. Yes there are many engine codes, some given originally were: LMG, LC9, LY5, LY6, L92, LSA. Choose your displacement and go from there. Your transmission will be 6L80E. Just make sure its 2011+ if your engine is 2011 plus. Yes there's a big brake kit, I think Alcon was working on something snd there's another company that someone posted in this thread. Nicholas makes a downpipe with cats that bolts to the NAS style cat back. You should be ok on stock axles depending on what engine and how you drive it. Any off-roading and you will want upgrades.
Old May 19th, 2016, 07:42 PM
Landy_Andy's Avatar
Landy_Andy
Andy
And if you wanted to keep costs down and go with a manual box, go read the Gen III thread
Old May 19th, 2016, 07:45 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
All:
Thanks!
Paul.
Short answer is:
-You can run any of the Gen IV engines, whether 4.8, 5.3, 5.7, 6.0 or 6.2. They each have their own engine codes, often times several for a given displacement, so research and figure out what is best for your wants and needs. If you're shopping for all new pieces, Turnkey Engine Supply offers a very nice engine and transmission package using the L94 that is configured for these trucks for around $14,000.
-The ONLY transmission supported by Nick's kit is the 6L80. Unfortunately it isn't the most common transmission out there so if you're hoping for a complete powertrain out of a wrecked vehicle you're going to have to scour pretty thoroughly. I believe only the 6.0 and 6.2 equipped vehicles came with the 6L80 from GM but I could be mistaken.
Marks 4WD in Australia offers a kit for the much more abundant 4L80 but after having just completed a swap using their kit I'll never use it again. Nick's is far superior.
-If you aren't drag racing or doing any crazy offroading you ought to be able to make the stock R&P and axles last just fine. Drive like a madman and you'll probably need to upgrade to chromo shafts and stronger gears.
-Alcon and Tarox are two that come to mind. Not a complete necessity but you can't have too much braking power in my opinion.
-If you use Nick's Y-pipe you can use any of the cat-back exhaust systems available for the Defender from companies like NRP, Borla and Magnaflow.
That should get you started.
-Ash
Geared Restoration Co.
352-572-3236
Old May 19th, 2016, 07:51 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Originally Posted by phoenix37 View Post
Love how this thing tows now!
Very nice Whaler!
Email:
Old May 19th, 2016, 07:55 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Hydro-boost is coming for the Defender! Stay tuned.
Old May 19th, 2016, 08:13 PM
phoenix37's Avatar
phoenix37
john
Many 09 and newer silverado, sierras, tahoes etc came with 5.3s and 6l80s...
go to car-part.com you'll find plenty.
Old May 19th, 2016, 08:34 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks guys!
For those of you who don't know, I'm building my Ninety to take to the USVI when we retire in 5 years. Very steep hills, max. Speed is 35mph, so I'll need bags of torque.
Before I dive into researching the characteristics of the different displacements, is there one that shines above the rest in terms of low end torque?
I know the Tdi's have good torque, but I really don't want a diesel.
Last stupid question- do they all run on regular petrol?
Thanks again!
Paul.
Old May 19th, 2016, 08:49 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
https://en.m.wikipedia.org/wiki/LS_b...e#Generation_V
Old May 20th, 2016, 05:03 AM
swaini
alswaini
97defender 90 st converted to NAS
Smile
hi,
thanks for the reply, the use is i guess 50/50 off/on road. we don't do much rock crawling here, soft sandy dunes, i luv to play with the right pedal. theres a video of 110 that nearly clipped a wrangler somewhere in this discussion; i was there physically and my friends were lucky nothing happened but back to the subject ; thats the kinda play we need here to tackle 100ft sand dunes.
as to my differential I'm using aschcrofts air lockers front and back. wheeling is 35 inch toyos all terrains on 16 inch terrafirma beadlocks.
Originally Posted by Red90 View Post
That depends on how you use it. It will be fine on the road. Off road use is the question and depends on the type of wheeling and how much you like to play with the right pedal.
What differentials do you have? You say shafts, flanges, R&P and CVs, but nothing about differentials.
swaini
alswaini
Smile ls 90 /130 project
hi,
Old May 20th, 2016, 05:26 AM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
what sort of fuel mileage do these trucks get with the LS?
Is there an option yet for a manual transmission? Seems a shame to lose the manual for an auto
Old May 20th, 2016, 05:59 AM
No pain no gain.
Old May 20th, 2016, 10:05 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Re: post #1267
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
