GM Gen 4 conversion including LS - Page 62 - Defender Source
Old May 17th, 2016, 08:15 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
1. Slide it on oriented correctly. You won't be able to rotate it into position.
Bolt it to the transmission first.
2. Plug it in.
Old May 17th, 2016, 08:42 PM
Shift the range shifter up. Are you sure it is installed right? I thought the shifter did not go that low and that it should be vertical for the neutral position.
Old May 17th, 2016, 09:02 PM
nealcain
Neal Cain
1988 D110
I put my vise grip on it and tried to shift it but it would only move one click and not allow the adapter to slide down in place. I will give it another looking at tonight...maybe bend it into submission.
At this rate I should have it done in about a years time.LOL
Old May 17th, 2016, 09:10 PM
Don't force it. It appears the shift rod is installed wrong on the transfer case
Old May 17th, 2016, 09:16 PM
Take off the cross shaft housing and have a look. The fork is located on the shaft with a grub screw that goes into a hole on the shaft inline with the external selector. I'm not sure how it is possible to have been put together wrong.
Old May 17th, 2016, 09:53 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
here's a photo of what it should look like...
ID:	149782   Click image for larger version
Old May 17th, 2016, 10:36 PM
nealcain
Neal Cain
1988 D110
Ok I see the correct orientation and it is not like mine. It could be installed wrong or I have not shifted it enough to clear? How many click positions does the shifter have...I can move it 1 click = 2 positions.
Old May 17th, 2016, 11:27 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
It shouldn't go "flat" pull the housing and check to see that the fork is in it's proper position sitting in the shift rod. Pretty sure it's not...
Old May 18th, 2016, 01:56 AM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Rotate the gears (both flanges or one of them with the diff locked) and try to shift it while rotating the gears.
I'm for the Russian pencil
Old May 18th, 2016, 02:10 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Does anyone in WA/OR/ID have a GM gen IV or LS truck I can look at before I spend a million dollars doing the swap on my Ninety? Anyone taking their GM engined Defender to the Portland ABFM in September?
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old May 18th, 2016, 02:46 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Check with Doug, I know there is a local that has an LS powered RRC. Maybe he will know someone with a Defender.
Ryan
84 110SW County LHD
07 L322 Vogue
Old May 18th, 2016, 06:05 PM
nealcain
Neal Cain
1988 D110
So it seems there are different levers depending on your engine code and Ashcroft made mine accordingly.:face palm: I do not know if the levers are different but it looks like I could just loosen the set screw and adjust the lever position?
If this does not work does anyone have a housing and lever for sale.
Old May 18th, 2016, 06:19 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
I've got a couple of them…
Old May 18th, 2016, 10:45 PM
At least on mine, the set screw goes into a hole so it will only work on one setting.
Frank, that LT230 is from a RRC right? Any chance you could take a close up photo with the neutral warning lamp switch removed? I am considering drilling/tapping a hole in my housing and adding this sensor. I have a spot that looks like to might be the right spot, but it isn't any thinker there and the circle area is not flat, but at a bit of an angle to the rest of the side go the housing so might not be a good spot for it.
Also, is this really only detecting neutral, or does it indicate high versus low? Because that's what I'd like it for.
Originally Posted by pendy
I'm here for the D's
Old May 18th, 2016, 11:02 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Tcase is from a D1…there 3 different shift housings
I'll take some pics and update you tomorrow…
quick edit, hi-low is on the output housing, you can see it the second pic
I have a couple of front output housings too, if you need one with the sensor (trade or something)
Old May 19th, 2016, 07:57 AM
Mostlymonki
Matt
1998 130, 1988 110
Originally Posted by mattarm View Post
Thanks all. Pretty much matches what I have in place.
Are you guys using a crossmember too? I hadn't even thought about it until I saw your pics without one fitted...
Old May 19th, 2016, 08:05 AM
mattarm's Avatar
mattarm
Matt
1993 D110
I will be using stock cross member. Just not installed yet.
Old May 19th, 2016, 09:25 AM
Mostlymonki
Matt
1998 130, 1988 110
Is that a stock v8 crossmember? Just had anot her look at my 300tdi 130 and the crossmember has the gearbox brackets welded on from the factory.
Old May 19th, 2016, 10:20 AM
SGS714's Avatar
SGS714
Scott Striglos
3xRRC 2xD90 2xD110 Series II, IIA
We are using the stock xmemeber with a 1" piece of steel to lower it in my RRC.
------ Follow up post added May 19th, 2016 09:26 AM ------
Originally Posted by swaini View Post
hi every one,
I'm running an rpi stageIII 4.6 v8 , and I'm going ahead with the swap, why? thats a discussion on its own and i don't want to pollute this amazing discussion. swaini
Can't help but mention I owned a RPI Stage III 4.6 and it was lackluster at best. Rebuilt top end 2x and set it out back to rust after 45k miles. Don't mean to sidetrack discussion but I still have hard feeling 4yrs and $10k later.
Thank you,
67 Series II
71 Series IIa 88" ACR 2.8 Power Plus
89 RRC 2 door VM 2.5TD
93 D110 NAS #327
94 2x D90 NAS #'s 1076 ACR 4.8, 1161 SBC
94 D90 NAS now a D110 HS 2.8 aka Project Wolf
95 2x RRC
1-SWB,Doing the LS Gen IV 98% Done
1-LWB 300tdi
Old May 19th, 2016, 10:48 AM
Jaded-7
Harrison
Does anyone know the Diameter of the stock maf tube for a 5.3? Wondering if we have to use the adapter and an older style MAF or if we can use something like this and the stock sensor.
http://www.amazon.com/dp/B0035GZSP8/...F4JMRJ1X39CB36
Of course spectre only makes a 3 and 4 inch version, where the old style had a 3.5 inch inlet i believe...
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
