GM Gen 4 conversion including LS - Page 61 - Defender Source
Old May 8th, 2016, 01:00 AM
SGS714's Avatar
SGS714
Scott Striglos
3xRRC 2xD90 2xD110 Series II, IIA
Originally Posted by Z06801 View Post
Has there been a build on a RRC yet? I had hope to have mine going by now but had to put it off for a bit.
After 17 months of a RRC build I have just filled my 3rd tank of gas. Have a few pics in my registry. I have yet to push it very hard and can tell you sometimes it's easier to just put the truck in neutral at a stop light then stand on the brakes as hard as you have to....it has a lot of torque and just wants to go.
I might change my signature to read 99% done.
Thank you,
67 Series II
71 Series IIa 88" ACR 2.8 Power Plus
89 RRC 2 door VM 2.5TD
93 D110 NAS #327
94 2x D90 NAS #'s 1076 ACR 4.8, 1161 SBC
94 D90 NAS now a D110 HS 2.8 aka Project Wolf
95 2x RRC
1-SWB,Doing the LS Gen IV 98% Done
1-LWB 300tdi
Old May 8th, 2016, 01:44 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Your brake signal may not be connected correctly to the ecm. It's required to unlock the torque converter. Connect the AutoCAL and pc to verify the input.
Old May 8th, 2016, 02:07 AM
SGS714's Avatar
SGS714
Scott Striglos
Awesome Nick...That makes a lot of sense. I'm on it next time it is in the shop. I still haven't loaded the last tune you sent me to deal with the tach. Appreciate It!
Thank you,
67 Series II
93 D110 NAS #327
95 2x RRC
1-LWB 300tdi
Old May 8th, 2016, 08:01 PM
Jaded-7
Harrison
So any updates on when the adapters will be done?
Old May 11th, 2016, 05:05 AM
nealcain
Neal Cain
1988 D110
2wd 6l80
I see people have cut the output shaft on a 4l80 and was wondering could you convert a 2wd to 4wd 6l80 by cutting a 2wd shaft and add the 4wd flange?
Please let it be this simple.
Old May 11th, 2016, 05:19 AM
UL1700
James
Defender 50th
Give or take, there are a couple of core plugs needed as well, written up in my build here...
http://www.defendersource.com/forum/...ild-58134.html
Old May 11th, 2016, 01:51 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
The 25 housings were just shipping from the foundry. They have to be machined, then shipped to me. Looks like two more weeks.
Old May 13th, 2016, 12:27 PM
swaini
alswaini
97defender 90 st converted to NAS
Smile will she take it!!!
hi every one,
I'm running an rpi stageIII 4.6 v8 , and I'm going ahead with the swap, why? thats a discussion on its own and i don't want to pollute this amazing discussion.
.i have a question regarding if my diffs and shafts will take the extra grunt from a 6.2,
i read on the discussion (can't remember which page) that it would be sensible to upgrade the diffs and shafts. my diffs and shafts were supplied by ashcroft about 2 yrs ago. the diffs are ring and pinion 4.12 ratio front and rears with heavy duty aschcroft half shafts, heavy duty flanges and cv joints.
the transfer case is limited slip 230 at a ratio of 1.22.
your opinions please as I'm restoring a 130 and would like to order her diffs etc soon and don't wanna make any expensive mistakes.
thanks in advance
swaini
Old May 13th, 2016, 12:51 PM
Originally Posted by swaini View Post
hi every one,
thanks in advance
swaini
That depends on how you use it. It will be fine on the road. Off road use is the question and depends on the type of wheeling and how much you like to play with the right pedal.
What differentials do you have? You say shafts, flanges, R&P and CVs, but nothing about differentials.
Old May 13th, 2016, 06:31 PM
phoenix37's Avatar
phoenix37
john
Love how this thing tows now!
ID:	149489   Click image for larger version
Old May 13th, 2016, 07:04 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Transmission Bracket
Can someone shoot a pic of where Part 3 (as called for in the BOM) is used in the build?
which looks like
Seems like there are several pics of the drivers side mounts in the thread but I did not come across any of this used on the passenger side. My drivetrain is in and I did not use this part, but rather #5. I cannot see how #3 is used so either I am wrong or I have an old/inaccurate BOM.
Old May 13th, 2016, 07:07 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Picture is not accurate. Right side lt230 mount should be a flat plate. Get everything from a D1.
Old May 16th, 2016, 09:46 PM
nealcain
Neal Cain
1988 D110
Bom
2 question and more to come
1.Please explain, I have #1,6 bracket from my BOM list. I do not have #3. If this is not the correct bracket then what 3 brackets do I need?
2. My ashcroft transfer case has a stud bolt in the way of Nicks adapter...do I pull this stud?
Thanks for clarification.
ID:	149687   Click image for larger version
Old May 16th, 2016, 10:58 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Remove the stud...
Old May 16th, 2016, 11:21 PM
Just be aware that that connection and the one below it go into the case. The bolts must have thread sealant or you will get a leak. The upper one that has the stud currently is in front of a gear. Make sure the bolt you use is not too long or it will hit the gear.
Old May 16th, 2016, 11:23 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Don't forget both dowels.
Old May 16th, 2016, 11:37 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Here are pic's of both sides mounting brackets :
Old May 16th, 2016, 11:39 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
which looks like
I do not think the diagram is accurate. I removed everything from a D1 with an auto trans and ended up with a bracket that looks identical to #5 for the right side. Everything lined up fine with the stock holes in the frame.
Old May 17th, 2016, 12:32 AM
mattarm's Avatar
mattarm
Matt
1993 D110
Thanks all. Pretty much matches what I have in place.
ID:	149713   Click image for larger version
Old May 17th, 2016, 08:02 PM
nealcain
Neal Cain
1988 D110
Ok gotcha, Thread sealer on top/ bottom bolts and 2 dowels.
1.I removed the stud bolt on the transfer case but I still can not rotate the adapter to the correct position as the shift lever is in the way. What am I doing wrong?
2. Just got my Lokar pedal assembly today. Can someone shine some light on what it takes to wire it up?
Thanks everyone for the helpful info....I hope my question help others with there build.
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
