GM Gen 4 conversion including LS - Page 6 - Defender Source
Old February 3rd, 2014, 02:38 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
In Beavis voice "me too"
Robert Deniro
Old February 3rd, 2014, 09:16 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Finally made it through this whole thread....
Good to see Nick's multi-year effort on this finally starting to pay off. I know at our local club's annual "Nick's Shop, Pool, and BBQ Experience" this has been in-real-life rover porn for a while now.
I had the pleasure of driving a prototype in Ocotillo Wells last year, and the fact I could spin all 4 wheels in the sand when I hammered it down put a shit eating grin on my face for sure.
It's even got me thinking about tossing the 300Tdi and putting in an LS.
Old February 3rd, 2014, 10:04 PM
Landy_Andy's Avatar
Landy_Andy
Andy
If you add one of these.... Double the grin factor !
Old February 3rd, 2014, 10:16 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
How bout just LSA...says it will fit!
Old February 3rd, 2014, 10:47 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I guess if ya got $20k to drop on the engine & box.....
Old February 4th, 2014, 01:31 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
RHD Tdi
Originally Posted by exmod110 View Post
ok, NICE set up!!!!!
What about in a RHD unit??????? that had a 300tdi,HMMMMMM????
It should fit a right hand drive. My only concern is the reversed panhard bar. When you compress the suspension on a LHD, the front axle/diff moves away from the oil pan. On the RHD, it moves closer to the oil pan.
The 300Tdi engine mounts won't work. They are too far back. Not sure if I can use them at this point. Maybe with a clever bracket. I would need a guinea pig.
Old February 4th, 2014, 01:47 PM
Out of curiosity, why are you running driveshafts with double-cardan joints front and rear?
Old February 4th, 2014, 03:02 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
3" lift, 35" MTs, 12" travel Bilstein 7100 remote reservoirs, cones, front and rear. It's a rock crawler.
Old February 5th, 2014, 11:07 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
A late model 2-Door Range Rover Classic with an LS motor is one of my dream vehicles - this is going to get me in a lot of trouble...
Old February 5th, 2014, 11:25 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Fo sure!
Rent my
Old February 6th, 2014, 05:23 AM
CDeWan
Clay DeWan
5.3L beastie
I will be bringing one of nick's creations to Raleigh someone in mid April when I finish my relocation. I won't say which one of his creations but if you want to test drive a 90 with a GM v8 with 300 plus ponies on tap let me know.
Old February 6th, 2014, 08:18 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Old February 6th, 2014, 08:36 AM
LR Max
Thomason, Max
1973 Series 3 109
Guess this won't fit into a series. The engines overall looks too long even if the transfer case was to be pushed back.
Old February 6th, 2014, 08:52 AM
ezzzzzzz
Mark Garrenton
Not without major work. I ran a 4.3 V6 for years in my '71 88" but used a NV4500 and Dana 300 coupled to Dana 44 axles. Even this required replacing the front crossmember, using a 4 bolt GM PS box, a modified D90 radiator support,D90 hood and modifying the bulkhead to clear the exhaust manifold.
That said, I've been working on a project for way too long that uses a D90 chassis shortened to fit the 88" body and D90 front bits. It is powered by a LS1/4L60E/Dana 300 all coupled to Currie Hi-pinion 9" axles. It has sat dormant for over 2 years as I've built my new garage. I hope to get it up and running in time for this years MAR and Conclave.
Old February 6th, 2014, 09:28 AM
LR Max
Thomason, Max
1973 Series 3 109
I was thinking of going with a V6. The newer V6 engines have plenty of power considering where I'm coming from. Oh and keeping that 6 speed auto would be sweet and also compact. Finally I was thinking of giving up on the rover transfer case and axles. That way a bolt on transfer case could be used and since my axles are toast anyway, not that big of a deal to get rid of them.
I guess a guy can dream.
Old February 6th, 2014, 10:01 AM
They should, but with a different gearbox. I have a friend running a SBC in his series and it all fits fine. He is using an old 4 speed manual box mated to the Series transfer case.
Old February 6th, 2014, 11:41 PM
Yep, definitely want to get a look and a drive in it I'll buy the beer afterwords too
95' D90 - daily driver..
Old February 8th, 2014, 11:50 AM
3rovers's Avatar
3rovers
Dennis Yard
1993 NAS D-110 #55
Add my "ditto" on that. Nick's attention to detail and superior research skills yielded my NAS 110's conversion to ZF automatic with a Lokar shifter that looks like the original.
Other than the missing clutch gear, you can hardly tell that it has been converted.
Follow up post added January 31st, 2014 10:38 PM ------[/SIZE]
sorry rabling here but Nick does have several other items he has engineered such as fitting a Lokar shifter to a rover automatic in case you want to change your R380 to a classic tranny which includes a block off plate for the whole left when you take ou the clutch pedal. It clears the Defender AC and puts the shifter in the same spot as the original stick.
Dennis Yard
Land Rover Club of San Diego
1993 NAS D-110 #55 (GNUTRUK)
2004 Disco II (DSCO DOG)
Old February 8th, 2014, 08:37 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Trans Cooler
Hope to fire the engine tomorrow.
ID:	89343   Click image for larger version
ID:	89345   Click image for larger version
Old February 8th, 2014, 08:39 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Originally Posted by nmarkiw View Post
Lokar Shifter
One more shot of the shifter.
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
