GM Gen 4 conversion including LS - Page 58 - Defender Source
Old March 31st, 2016, 03:55 PM
GOYA
Dane McDonald
1988 Defender 90
Nick, email & pm sent to purchase mounts. Let me know what else you need from me.
Old April 2nd, 2016, 12:38 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Forgive me if this was talked about here. I have read through all of this thread but don't recall seeing much about a tranny cooler for the auto. Is it necessary? If so what cooler are you running?
Old April 2nd, 2016, 12:47 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Yes, Permacool with Fragila stainless lines. It's in the BOM. Also there are pics early in the thread.
Old April 3rd, 2016, 01:32 PM
Mostlymonki
Matt
1998 130, 1988 110
I'm in the middle of reworking my harness, and I'm not sure what i'm supposed to do with the oil pressure switch thats in Nicks BOM - does it replace the stock sensor behind the intake manifold? given its a single connector I'm guessing id need to delete the wires and run it direct to the warning light?
Old April 3rd, 2016, 01:40 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Its for the defender warning light.
Old April 3rd, 2016, 01:45 PM
Mostlymonki
Matt
1998 130, 1988 110
thanks Nick, but where does it go on the engine?
Old April 3rd, 2016, 02:02 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Oil cooler bypass on the side of the oil pan. Gm part in the bom.
Old April 3rd, 2016, 03:10 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Like this :
I used an adaptor and 45 degree fitting (to clear the reversed intake manifold) to mount the VDO oil pressure sender in the original position on top of the engine :
Hope that helps.....
Old April 13th, 2016, 10:38 AM
Mostlymonki
Matt
1998 130, 1988 110
thanks guys
reading back through the thread again... did the vdo gauges not work in the end? hence everyone opting for the DD cluster instead?
Nick, if you've updated your bom recently could you sent it to me again please as I'm working from the one you sent me waaaay back.
Old April 13th, 2016, 11:53 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Originally Posted by Mostlymonki View Post
thanks guys
The VDO gauges work as expected. You have a choice.
Old April 19th, 2016, 06:03 PM
6 pot's Avatar
6 pot
Rob
more than one
Hi
My problem is the red battery light on the dash. I am using the GM crate engine control system and can find no way of making it work. The bulkhead connector has nothing is there a way?
Thanks Rob
2015 90XS CSW
1998 110 Wolf WMIK
1998 110 Wolf FFR
1995 90 Wolf FFR
1986 90 Ex MOD
1986 90 Ex MOD 6.3 LS3
1976 101 Hard top FFR
1972 101 Pre Production FFR
Old April 20th, 2016, 04:15 PM
phoenix37's Avatar
phoenix37
john
this is happening.. http://jeepbeach.com....means I'm surrounded by more mullets and neon jeeps than usual in Florida this week.. the silver lining is I got to leave several of them with their mouths wide open today as they got blown off the line by a crappy old land rover. Have i mentioned I love my LS swap?!
Old April 20th, 2016, 09:58 PM
johan's Avatar
johan
johan
2009 Range Rover
Without reading 1150 messages, is there a manual for the installation or a website explaining it?
I want to buy a set but after one mail from Nick it became quite, no answers anymore. Does anybody know how I can contact him, or Nick if you read this, can you contact me?
Johan
Old April 20th, 2016, 11:34 PM
defender1844
Amit Likhyani
I drove out to his house in San Diego. Nick is incredibly busy. He also has a full time job. It will be interesting to see if he ever spins this off full time. But be patient and work with him. The kit he makes is simply astounding. Here's mine with a 6.2L LS bolted in place but not yet wired up. It's actually a L94 crate motor from Turnkey Engine Supply.
Old April 21st, 2016, 12:59 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
My GOD! Look at that motor! Look at those shocks! Look at those....... Oh, forget it! Just look at that! ;-) NICE!
"Barry is correct!"
Old April 21st, 2016, 01:25 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Yes, read the 1150 posts.... In all honesty the install is fairly straight forward, Nicks parts are top notch and if you get stuck just post up here. Also go read the Gen III thread if your looking for a budget or manual option
Old April 21st, 2016, 01:50 AM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
I flew around the globe to his house
Great job by the way came out nicely
I'm for the Russian pencil
Old April 21st, 2016, 04:23 AM
UL1700
James
Defender 50th
Awesome aren't they! I have just driven mine its first 200km in the last 3 days. It has been sitting for a while since getting the exhaust fitted due to work commitments but having worked few out a few gremlins with fuel pumps and and a good old earthing issue we are finally on the road. I have a couple of hopefully minor tuning issues to sort but the thing very nearly flys
Old April 21st, 2016, 10:02 PM
johan's Avatar
johan
johan
2009 Range Rover
Without reading 1150 messages, is there a manual for the installation or a website explaining it? I want to buy a set but after one mail from Nick it became quite, no answers anymore. Does anybody know how I can contact him, or Nick if you read this, can you contact me?
Ok, Nick contacted me, Thx. I will order the parts from him.
I want to go for a new engine and transmission. Any suggestions where to buy and which configuration ? Did see the side of turn key engine supply but get confused which engine to take, so many different ones.
Johan
Old April 21st, 2016, 11:49 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
We went with Turnkey, L99 with the 6l80e combined with Nicks kit it's plug and play.
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
