GM Gen 4 conversion including LS - Page 53 - Defender Source
Old January 26th, 2016, 03:56 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
Pedal Options?
Originally Posted by phoenix37 View Post
I used the stock pedal and bolted the truck pedal that came with the motor to the outside of the bulkhead. Ran the throttle cable through the LS pedal arm so that the cable would depress the LS pedal when you stepped on the stock pedal. this was a rough mock up before i trimmed the cable and added washer etc. Ultimately i abandoned this set up and bit the bullet and bought the lokar. there was just not enough travel for me to feel safe. felt like almost instant WOT. Im sure there is a version of this that could work but didnt experiment further with it.
In a cost savings effort, has anyone tried the Corvette ETC pedal? It's $100 from Speartech instead of $400 for Lokar pedal and control module.
Corvette ETC Pedal
Old January 26th, 2016, 06:25 PM
UL1700
James
Defender 50th
Corvette ETC Pedal
Yes and there are side by side photos in my Defender 50th LS2 / 6l80 Build At the time the mods looked easy but the pedal has to be shortened and changed from a RH to LH offset and the vertical angle changed. During this process I managed to damage the sensor due to a stupid mistake with the vice. I ended up buying the Lokar Peddal as I wasn't game to keep shipping them to OZ
On a side note, I have just ordered my dash from Dakota Digital and was wondering if anyone has used the GM Drive by wire cruse control kit... Cruise Control for GM LS Drive-by-Wire Engines
Old January 26th, 2016, 07:32 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by ECR View Post
Thanks Nick for the adapter. Great stuff.
Damn! That is so nice
Old January 26th, 2016, 08:34 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
my dick moved, color matched valve covers... Feel like nick cage in that awkward Angelina Jolie scene from gone in 60 seconds
Old January 26th, 2016, 08:51 PM
Landy_Andy's Avatar
Landy_Andy
Andy
More pic's..... please.... and
Old January 26th, 2016, 09:08 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
There are pictures of that project on our Facebook page.
When it is 100% done (its about 90% done right now) I will put it on the ECR web site so all can see it.
Nick's parts and idea made it possible, so big thumbs up to him. After having driven this truck, I am having a really hard time trying to find any argument for why a Rover V8 should live in that space.
Email:
Old January 28th, 2016, 04:17 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Belt Clearance
Nick,
Is this the expected belt clearance at the water pump? Brand new belt and it appears to be less than 2mm clearance.
ID:	140693   Click image for larger version
Old January 28th, 2016, 04:33 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Originally Posted by mattarm View Post
Nick,
Looks correct. You used the smaller Dayco idler pulley next to the alternator?
Old January 31st, 2016, 11:44 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Dakota Digital
I finally got around to installing the Dakota Digital gauge cluster.
Designed a transition plate. (non Puma)
ID:	140898   Click image for larger version
Old January 31st, 2016, 11:47 AM
That's cool. You should get a nice Raptor steel binnacle to put it in.
Old January 31st, 2016, 12:04 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Way too much bling..... you should send that my way
Old January 31st, 2016, 03:08 PM
UL1700
James
Defender 50th
Nice choice, I have this on order
Old January 31st, 2016, 08:37 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Affirmative.
Old January 31st, 2016, 09:08 PM
Way of Life's Avatar
Way of Life
1988 Defender D110
Dam all this stuff gets me thinking.........fast stuff.
All the gear you guys show is sweet.
keep all the information coming, does anyone know of someone doing the Ford 5.0 coyote.
I just like the blue oval/ green oval.
I like the power in the LS3 and the down low power looking at the numbers.
I think to pull the motor and just wire the puma dash with a painless and then the Ford or Chevy Factor wiring. I have the puma dash and the MT82 so the transfer case should match the ford stuff.
Land Rover Defenders. 65 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy.
Old January 31st, 2016, 11:16 PM
defender1844
Amit Likhyani
UL1700, can you provide a source for that gauge cluster like vendor, URL and price? More importantly, Nick, will your harness work in such a way that the Dakota digital or UL1700 fuel gauge portion works with some fuel pump whether factory, aftermarket or combination aftermarket pump with factory sending unit? I've got my motor out and an L94/6l80e slated to arrive in 4 weeks. I assume the gauge is can bus based. Please provide any info guys.
------ Follow up post added January 31st, 2016 11:22 PM ------
google reverse search is pretty bad ass. http://www.summitracing.com/parts/dak-vfd31008b
Is there enough room to leave the OEM info panel in the dash with the Dakota series III? It's 4.25 inches tall.
Old January 31st, 2016, 11:23 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Amit,
The Dakota Digital gauge setup and the engine harness are mutually exclusive. You can use the CAN bus or discrete wiring for the fuel sensor. Any calibration. However, for the EVAP I/M (California) to work correctly you have to wire the fuel level sensor to the E38 and then get the gauge reads from the CAN bus.
The setup allows you to pick your sources for the gauges. For example, speed, CAN bus, VSS, or GPS.
------ Follow up post added January 31st, 2016 09:24 PM ------
Nope
Old January 31st, 2016, 11:41 PM
UL1700
James
Defender 50th
The DD website is not a bad place to start...
VFD3-1008: Universal 4.25" x 12" Oval, Digital VFD Instrument
Most of the info panel warning lights are also on the dd Dash
Old February 1st, 2016, 11:06 AM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
You need the BIM-01-2 CAN bus module also!
Old February 1st, 2016, 02:07 PM
Jwillia's Avatar
Jwillia
Justin
87 ROW build in progress
@nmarkiw and everyone else. I am letting my Lc9 drivetrain with nicks killer adapter go if you know anyone interested. I am gonna throw it in the for sale section, but in case you know anyone in SoCal lemme know 6k Click image for larger version
Old February 1st, 2016, 07:36 PM
UL1700
James
Defender 50th
What made you stop? It looks awesome!
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 05:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 11:58 AM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 08:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 04:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 08:33 PM
