GM Gen 4 conversion including LS - Page 52 - Defender Source
Old January 18th, 2016, 10:57 AM
evoblade
Bob
2004 Discovery II
prices?
Nick,
Could you please send me a PM or a link to price list?
Also, could this kit work with one of the 4 speed transmissions? It would make my motor shopping a lot simpler if Gen III motors were an option, but using the 6L80 makes that a lot harder.
EDIT: ebay selection is subpar, I guess there are plenty of trannys out there.
Old January 18th, 2016, 12:40 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
1994 NAS D90 LS 5.3L
Originally Posted by evoblade View Post
Nick,
This configuration does NOT support any 4-speed automatic transmissions. 6L80e only and that requires the Gen IV engine.
Mark's 4wd Adapters has a 4L80e adapter. Be prepared to relocate the LT230 with their configuration.
Old January 18th, 2016, 01:32 PM
Z06801
Park
1995 LWB RRC
With your kit will the LT230 stay in the same location as the stock T-case? 95' LWB RR
Old January 18th, 2016, 02:23 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Correct.
Old January 18th, 2016, 03:09 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Or go with Gen III and a manual NV4500 if that'd work for you as it keeps it in the stock location.
Old January 18th, 2016, 03:24 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Not in a Classic. The shifter would end up under the dash.
Old January 18th, 2016, 10:40 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Expansion Tank
New product...
ID:	139808   Click image for larger version
Old January 24th, 2016, 03:15 PM
Mostlymonki
Matt
1998 130, 1988 110
Umm.... 4" off the MAF I believe....
I was looking at one of these for a snorkel setup :
Ump 4 Inch Super Air Filter With 8 Inch Extra Long Canister For Engines That Have 250Hp To 300Hp
Or you could use a truck filter like on Rob's ORA Eurofighter....
thoughts on this? inline air box
3inch inlet/outlet, and 4 inch o/d so should be able to squeeze it in somewhere (even integrate it into a snorkel).
Old January 24th, 2016, 04:32 PM
Landy_Andy's Avatar
Landy_Andy
Andy
I think that it'll be restrictive being only 3".... was looking at making something like this with a 4" inlet/outlet :
Air Box (Universal)
This is an interesting design, could do something along these lines quite easily.....
http://www.millweld.com/a/Airboxes
Another option might be using a commercial truck filter in a custom housing, sort of like a Donaldson.... but got to get my sch'd 40 manifolds made first though
Old January 24th, 2016, 05:02 PM
86Defend110
Jesse
86 Defender 110 LS 5.3 In Progress
Originally Posted by 35xj View Post
Sent a pm regarding price. But does anybody know the total overal length of a 5.3/6l80/230? Trying to cram it into a series project....
I come up with approx 69" from the front of the water pump pulley to the end of the drive flange bolts on the transfer case.
Old January 25th, 2016, 08:51 AM
Raven81's Avatar
Raven81
Todd
1997 NAS D90
Apologize for the Hijack, or if Nic has already posted this; but can someone tell me the exact distance from bell housing to the back of the LT230 case using Nic's adapter. I see 69" total above, and the engine is 28.75" from front pulley to flywheel, which leaves approx. 40.25". But hoping someone can give me the exact dimension.
I'm just trying to compare Nic's set-up to Rakeway's T56/LT230 set-up or their TKO600/LT230 Set-Up, to see if the rest of Nic's Gen 4 set-up (mounts, radiator, etc...) will work.
Old January 25th, 2016, 10:19 AM
86Defend110
Jesse
I measure approximately 40.25" from the front of the bell housing to the back of the drive shaft flange on the LT230. 41.5" to the end of the drive shaft flange bolts.
Old January 25th, 2016, 05:09 PM
86Defend110
Jesse
Originally Posted by Davis View Post
Great idea to put that heat deflecting fabric around the engine mount rubber... I should consider that the next time I change them.
If your take out motor comes with the original heat shields you can reuse them. If you are getting your motor from a salvage yard, ask them to include the shields.
ID:	140395   Click image for larger version
Old January 25th, 2016, 08:43 PM
sulli270
sean sullivan
84 D90 2.5 NA
Nick, I've been looking at your product for a while and this conversion something I am going to want to do (maybe not right away, looking at putting together a summer project). Can you PM me the pricing on the adapter for converting an 84 2.5 N/A Diesel D90?
Also I was wondering if there were any technical limitation on putting in the new 8 speed transmission, from what I can tell the size is just about the same as the 6 speed and as I would like to source a new transmission anyway, it seems to make sense to get the newest and shiniest of GMs transmissions. Alternatively (and I know this one is a stretch) what is the limitation on using a TR6060 manual transmission? That trans seems like it would bolt up in nearly the same way as the 6 speed auto and would give people an option to go manual that isn't from an orphaned manufacturer like the NV4500.
Thanks.
Old January 25th, 2016, 11:58 PM
nmarkiw's Avatar
nmarkiw
Nicholas Markiw
Nice.
I have a pair of these laying around. I will see if I can find a GM part number.
Old January 26th, 2016, 09:43 AM
Mostlymonki
Matt
1998 130, 1988 110
Nick, I was reading back through the thread again and spotted you'd mentioned you were thinking of doing reflashed BCM's with harnesses (rather than just the whole engine harness) - are you still doing that?
I've just started on reworking my factory harness, so could use any info you have on what wires I need to leave for you're bcm harness if you are...
Old January 26th, 2016, 10:39 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by sulli270 View Post
Alternatively (and I know this one is a stretch) what is the limitation on using a TR6060 manual transmission? That trans seems like it would bolt up in nearly the same way as the 6 speed auto and would give people an option to go manual that isn't from an orphaned manufacturer like the NV4500. Thanks.
The TR6060 is only RWD isn't it.... you have to go to a Tranzilla box if you want 4WD and that's $$$$$
Old January 26th, 2016, 04:18 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Thanks Nick for the adapter. Great stuff.
Email:
Old January 26th, 2016, 04:24 PM
phoenix37's Avatar
phoenix37
john
sweet..what coil covers are those?
Old January 26th, 2016, 04:32 PM
86Defend110
Jesse
Wow, beautiful engine compartment! Looks great, almost too nice to get dirty!!
conversion
110 rear disk brake conversion c2sox Defender Technical Discussions 14 September 23rd, 2016 06:23 PM
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
RHD to LHD conversion Reefminis Defender Technical Discussions 5 May 21st, 2005 05:23 PM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
